audio help
Old Sep 30, 2012 | 12:26 PM
mrkhone's Avatar
audio help
i just installed my hu in my car. it has stock bose. i'm using the 75515 harness. i installed it right the first time. it worked then i decided to wire the other ground to the headunit ground. which i think popped somehting and now headunit will not power on. hu makes whirring noise and when i put the stock bose hu back it it makes popping noises. any thoughts anyone
Old Sep 30, 2012 | 09:10 PM
EvanMax41's Avatar
Okay, try this. Replace the fuse, it may have blown. When i changed out my radio i grounded my radio to a 10mm bolt behind the rear seat. But i think i could really just be a simple blown fuse.
Old Oct 1, 2012 | 01:49 AM
mrkhone's Avatar
U know which fuse. I've looked at the audio and Bose fuses under the dash and they didn't look blown
Old Oct 1, 2012 | 06:16 AM
dwapenyi's Avatar
There's an audio fuse in the engine bay as well.
Old Oct 1, 2012 | 06:40 AM
mrkhone's Avatar
OK ill check that one and just ground the other wire to the frame
Old Oct 1, 2012 | 07:46 AM
EvanMax41's Avatar
Yeah i think the audio under the hood fuse it a 20AMP yellow fuse.
Also like i said before a great place to ground the radio is behind the rear bench. 10mm screw
Old Oct 1, 2012 | 09:23 AM
ShocknAwe's Avatar
grounding a HU behind the rear seats? If I am hearing you right that is a bad idea. A ground cable shouldnt be more than about 18in
Old Oct 1, 2012 | 10:58 AM
mrkhone's Avatar
That's what I was thinking. Kinda far to ground it. But I looked under the hood and I don't see anything for the Bose or audio.
Old Oct 1, 2012 | 11:03 AM
maxinout93's Avatar
check the dash fuse, either u blew the bose fuse itself or the audio fuse. the bose fuse is a 15 amp blue fuse, the audio fuse is red and 10amp I believe.
Old Oct 1, 2012 | 11:07 AM
mrkhone's Avatar
I checked those already and they're good. I'm just gonna replace them anyways and hopefully it works
Old Oct 1, 2012 | 01:24 PM
mrkhone's Avatar
Old Oct 1, 2012 | 02:28 PM
mrkhone's Avatar
OK. It works now don't know what I did but it works. Lol
Old Oct 1, 2012 | 06:23 PM
dwapenyi's Avatar
FYI your profile says 2004 Maxima SL which means you have a 6th gen Maxima.
Old Oct 2, 2012 | 08:55 AM
mrkhone's Avatar
I have both a 4th and 6th Gen. Use the 4th as my work car
Old Oct 2, 2012 | 09:02 AM
cjanderson3's Avatar
From the sounds of it you may have created a ground loop. You might have better luck isolating the grounds (if I interpreted what you did correctly). This was a problem on older electronics but the principle still applies.
...But if you say it works now maybe I'm just jumping to conclusions lol
Old Oct 2, 2012 | 09:17 AM
dwapenyi's Avatar
Ground loops only happen in houses. In cars there's only one ground; the entire car.
Old Oct 2, 2012 | 12:28 PM
mrkhone's Avatar
Yeah. It works. Changed all the fuses. Ans redid the wires and it started working. Now I'm wondering why the bass doesn't hit like it did with the Bose. I didn't ground the amp round wire so maybe that's why. Not sure.
Old Oct 2, 2012 | 01:24 PM
dwapenyi's Avatar
The system will never sound as good. The Bose amp aren't straight amps. They EQued the audio signal as well.
My stock Bose system is interfaced with an aftermarket clarion HU with this;
http://www.ebay.com/itm/AudioLink-PD...p2047675.l2557
That PD-4 and necessary harness you can get from Crutchfield makes your Bose system killer.
Unfortunatley auidolink went out of business so you can only find those units on ebay now.
Old Oct 2, 2012 | 05:44 PM
mrkhone's Avatar
guess i'm gonna just add a sub for some bass then. but it does sound a lot more clearer.
Old Oct 4, 2012 | 07:48 AM
RushNatU's Avatar
Yeah that's probably your best bet. 6.5" speakers will never produce decent bass at loud volumes so maybe get some crossovers to filter the bass out of the speakers (this will make them able to go much louder without distorting) and get a sub.
I didn't start with the Bose system but I'm running a Polk 100w x 4 amp for my Polk components up front, and Polk 6.5" in the rear deck. Sub is Polk 12" w/ Kicker 400w amp (all rms). Head unit is a Kenwood 7" Nav/DVD. Sounds killer clean and makes my ears bleed at high volumes. The gf hates it lol!
Robert Schneeweis
Jan 11, 2017 06:47 PM
Fbana41
Aug 29, 2016 12:18 PM
Excalibur23
Oct 13, 2015 04:33 PM
BrandonCause
Sep 20, 2015 10:20 PM
popdedop
Sep 11, 2015 11:17 AM
