The mysterious missing problem
Old Oct 3, 2012 | 03:54 PM
theblackone3.5's Avatar
The 96 max has a little over a 100,000 miles on it. My problem is the max is missing under load in reverse, drive, first and second gear. There is no CEL on and its starting to get a little worse because its starting to miss in park and neutral now. Its not that noticeable or that bad in park and neutral but you can barely feel it though. Now for the things i replaced to try to fix the problem: new OEM double platinum spark plugs, new OEM maf sensor, new OEM TPS sensor, new OEM fuel filter, new OEM FPR, 6 new coils pack(can't remember if I got them OEM, I think i did but they are brand new), took the fuel injectors off and sent them off to get them cleaned and they are all working properly, there are no intake leaks, no vacuum leaks what so ever actually, I cleaned the IACV and it is working properly, I even had it scoped the other day and they couldn't find the problem either. So some one help me get rid of these miss, its really starting to annoy the crap out of me!!! Any help appreciated
Old Oct 3, 2012 | 04:06 PM
Amerikaner83's Avatar
get OEM coils.
Old Oct 3, 2012 | 04:10 PM
njmaxseltd's Avatar
That statement makes no sense. Are they brand new? If so one would think you'd remember what/where you purchased them
My vote goes to a weak coil pack.
Old Oct 3, 2012 | 04:13 PM
Yes their brand new just dont remember where i got them. Its been a few months ago. sorry about that.
Old Oct 3, 2012 | 04:24 PM
BigLou55's Avatar
I agree with the above suggestions. weak coil and if they aren't Nissan OEM replace it.
Old Oct 3, 2012 | 04:31 PM
any other suggestions if its not a coil? any other things that need to be replaced?
Old Oct 3, 2012 | 04:45 PM
njmaxseltd's Avatar
As far as your issue, Nope.
Old Oct 3, 2012 | 04:48 PM
How do you guys know its a weak coil pack? Where is a good site to get OEM nissan coil packs? much appreciated
Old Oct 3, 2012 | 04:52 PM
carsnwomen91's Avatar
they're like 150 a piece from nissan and the brand is hanshin or nissan. we know its a weak coil pack cause its missing. first thing that comes to mind is a **** spark.
go to a junkyard and yank off a few. they should be like 20 a piece from there or do your thang and get em fo free
Old Oct 3, 2012 | 04:54 PM
i like how it was labelled mysterious but the first post solves it lol it'll be mysterious if oem coils aren't gonna solve the issue.
Old Oct 3, 2012 | 04:56 PM
Thats hilarious carsnwomen91, hopefully this will fix the problem, now thinking of the glass half empty, what happens if it doesn't fix the problem?
Old Oct 3, 2012 | 05:22 PM
BigLou55's Avatar
Then we will help you troubleshoot from there but trust us...start with the coils.
Old Oct 3, 2012 | 05:32 PM
should i get an apexi vafc 2 for a tune or no?
Old Oct 3, 2012 | 05:46 PM
It doesn't ******* matter what you tune with if you've got misfires.
Old Oct 3, 2012 | 05:50 PM
just seeing if i need it or not? take a deep breath and relax. now u all better now
Old Oct 4, 2012 | 06:28 AM
bump
Old Oct 4, 2012 | 06:42 AM
jholley's Avatar
If you didn't pay hundreds of dollars for those new coils then they are no doubt aftermarket coils. Take the suggestion that many members have already given you and replace them with OEM coils.
I got 6 used OEM coils from our classifieds 3 years ago and they all still work fine.
Old Dec 26, 2012 | 07:15 PM
I put my oem coils back on with new boots, but still misses periodically but only at idle.
Old Jan 4, 2013 | 06:35 PM
bump
Old Jan 4, 2013 | 08:07 PM
tosheto's Avatar
System goes as follows: ECU - wires - coils - spark plugs.
Most likely your spark plugs are bad or your coils are crap.
Old Jan 5, 2013 | 02:33 PM
spark plugs are brand new. Original oem coils but new boots on all six.
Old Jan 6, 2013 | 08:06 PM
bump!!!!
Old Jan 8, 2013 | 09:03 AM
bump
Old Jan 8, 2013 | 09:21 AM
Fakie J Farkerton's Avatar
bump
Everyone has already said it. I'll say it a little different. Post a WTB in the classifieds here on the org asking for used OEM coil packs.
Put THOSE in, and report back.
Also, I hope you used NGK spark plugs.
Double check your connections.
It could be a bad MAF; I also recommend OEM used from the org. ~Start with different coil packs first.
Good luck.
Old Jan 8, 2013 | 09:42 AM
Good luck.
There are only so many ways it can be said...maybe the 5th or 6th time will work.
Old Jan 12, 2013 | 03:49 PM
Qmaxima98GLE's Avatar
get OEM coils.
is the coil pack the problem for miss fire
Old Jan 12, 2013 | 03:54 PM
cause other than that my maxx runs goos besides new shocks an struts don't wasn't to change then till I drop it and put adjustable coil overs and a lip kit for front and side skirts
Old Jan 12, 2013 | 03:56 PM
but I wasn't*
Old Jan 12, 2013 | 04:10 PM
SterlingMistMax's Avatar
There is definately something missing here lol
Old Jan 12, 2013 | 04:27 PM
steezmuffin686's Avatar
perhaps proper spelling and a clear concise explanation?
Old Jan 12, 2013 | 04:50 PM
missfire is almost always the damn coil pack
and what they are getting at is that if you are using remanufactured coil packs bought at an auto parts store and not nissan you are likely to still get a miss or still have the 1320 code . did they even check to see if it is giving them a code (SES) and what cyl it is ?
Old Jan 12, 2013 | 05:16 PM
GGENIUS's Avatar
holy FUKCIN **** THIS THREAD
Old Jan 12, 2013 | 05:28 PM
stromm's Avatar
Not to add fuel to the fire going on already, but...
Why would anyone chance used coils over remans?
You know, since the ones in his car ARE used and there's no guarantee that the ones from the junk yard or bought online aren't faulty too...
Old Jan 12, 2013 | 06:22 PM
I honestly think its cylinder 6 but not sure and I'm trying to get this fix asap it is annoying and that's about it just bought my max bout dec 1 it has like 202,987 miles and its ok but that miss just started 2 weeks ago but its ok
Old Jan 12, 2013 | 06:23 PM
and I'd appreciate some helpfuk tips and watt I should do to it handling minor motor work that's all and thanks
Old Jan 12, 2013 | 06:52 PM
if u raise in using a android and it spells wat it wants fukkn genius Smh it always gotta b a character...
Old Jan 12, 2013 | 06:53 PM
if u realize I'm using a android and it spells wat it wants fukkn genius Smh it always gotta b a character...
Old Jan 12, 2013 | 06:55 PM
so wat is ur suggestion on using for handling on my maxx I want something that's good for performance and also regular driving
Old Jan 12, 2013 | 08:58 PM
codysmaxima101's Avatar
coils
Old Jan 12, 2013 | 09:12 PM
Who thinks coil packs and coilovers are the same thing?
