1998 Nissan Maxima GLE 3.0L - 8-tooth Starter
Old Oct 16, 2012 | 12:19 PM
Brittany Ooms's Avatar
I bought a starter to replace my original 1998 Maxima starter, however the part that was apparently compatible is 8-tooth, where as the part I removed has a 10-tooth starter. I see on some guides that you can use an 8-tooth, but I'm wanting to make sure.
The 8-tooth works, but it sounds like it's struggling to turn over. It sounds way different starting up than the original did. Is the 8-tooth okay to continue to use? Is it damaging anything in there?
Thanks in advance for any help.
Old Oct 17, 2012 | 02:45 AM
flynlr's Avatar
the 10 tooth does turn it over quicker,. My 95 came with a 8 tooth and the replacement was a 10 tooth, much improved over OEM
Old Oct 17, 2012 | 09:08 PM
maxinout93's Avatar
I don't kno and never counted the teeth on my starter, but every five or six cranks, I get a scrape sound. it sounds as if you turn the key while the car is already running. I don't kno why it does that.
Old Jun 7, 2015 | 11:51 PM
Kevinmax's Avatar
Same issue
I ran into the same issue on a 97 Maxima with a starter that I pulled off a salvage 96 infinity I 30. The salvage yard interchange list said that it should be the same starter however the one that I pulled off was that an 8 tooth where as the one that was on my car was a 10 tooth. I noticed both of the starters were remanufactured so one of them (or both) could be the wrong one. Will the 8 tooth one be ok or do I need to find a 10 tooth one? Thanks for your help.
Old Jun 8, 2015 | 12:07 AM
I think even later years, 98 and 99, came with 11 tooth starters. If I was you, I'd track down a 10 or 11 tooth. To compare, walk in or call Autozone, Pepboys, Napa etc and see what they sell for comparison sake.
Old Jun 8, 2015 | 12:44 AM
Fauken's Avatar
Go to bed.
Old Jun 8, 2015 | 04:08 PM
Kevinmax's Avatar
Will I dammage my starter?
I guess the question I am more concerned with is if I use the 8 tooth starter am I likely to dammage anything beyond just the starter?
Old Jun 8, 2015 | 05:49 PM
maxinout93's Avatar
no you wont damage anything i dont think. I think the 8 tooth starters turn the engine over a little slower than one with 10 or 12 teeth. I had a few used 8 tooth starters burn out real quick. So i got one off of a 01 maxima that had 12 teeth, havent had a starting problem since.
Old Jun 8, 2015 | 08:44 PM
DennisMik's Avatar
The reason Nissan increased the teeth on the starter was to eliminate some starting problems. The cranking speed of the original 8 tooth starter was just borderline for the flywheel crankshaft sensor to produce a pulse for the ecu. Changing the starter gear made the engine crank faster and produce a more reliable pulse from the crankshaft sensor to the ecu.
Get an 11 tooth starter if you can.
xUNIxPanther
Aug 27, 2015 10:09 PM
District
Aug 15, 2015 08:23 PM
niZ
Aug 7, 2015 10:18 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
