Clutch Fluid Leak and Slippage
Old Oct 22, 2012 | 05:24 AM
laxbaby05's Avatar
I have a 97 Nissan Maxima, and took her on a nice long trip to florida (from CT). Getting back from this trip I found several problems that had to be replaced (starter, radiator and fan assembly).
When the starter went in Florida, we would just pop start it, which I knew would cause some wear and tear on the clutch. Since I've been back, just about every other day I have to fill the clutch/brake reservoir. I haven't noticed any fluid leaking directly under neath the car, but the clutch has become to slip majorly. I can hit the throttle to the ground, and you just hear the car rev as it would be in neutral.
Any thoughts as to what can cause this? Or has anyone had this problem? I want to do as many things to save the clutch as possible before having to change it *cause it is a ****** but its a last resort.
Old Oct 22, 2012 | 01:26 PM
njmaxseltd's Avatar
1) You need a new clutch
2) You have a leak in the clutch hydraulic line or slave cylinder.
Old Oct 22, 2012 | 11:33 PM
laxbaby05's Avatar
Well I guess the clutch will have to be changed. I looked at the slave...theres no fluid leakage around it, however the master cylinder looks pretty wet. Prolly gonna have to change that thank you for your advice!
Old Oct 23, 2012 | 05:18 PM
asand1's Avatar
Could be the hose between reservoir and MC. The clutch might have gone bad due to the mushy pedal causing it to drag rather than fully disengage.
Old Oct 26, 2012 | 07:59 AM
ryandaiber's Avatar
the fluid could be leaking in the bellhousing which would get fluid onto the clutch and cause it to slip
Old Oct 26, 2012 | 08:52 AM
asand1's Avatar
The slave cylinder is externally mounted. There is no fluid inside the bellhousing.
Old Oct 26, 2012 | 09:06 AM
ryandaiber's Avatar
no fluid is SUPPOSED to be inside the bellhousing. how would you explain where the fluid is disappearing to?
Old Oct 26, 2012 | 01:25 PM
[s3]'s Avatar
LOL that's a really good one, clutch fluid leaking into the clutch/flywheel and causing it to slip.
Old Oct 26, 2012 | 01:51 PM
315max's Avatar
please take a picture of the trans and point out to us where the fluid could be getting into the bell housing. damn newbie...do you even own a standard 4th gen?
Old Oct 27, 2012 | 04:41 AM
ryandaiber's Avatar
is it not possible that fluid could be passing the piston in the slave cylinder down the withdrawl lever and onto the release bearing which is inside the bellhousing?
Old Oct 27, 2012 | 04:06 PM
asand1's Avatar
It still wouldn't get onto the clutch disc.
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
fastcarny
Oct 12, 2015 07:06 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
pears
Sep 18, 2015 05:25 AM
