cam broken
cam broken
So,I'm in the middle of doing my 3.5 swap. And right as I pull the cams to install them I notice, one of them is bent and cracked at the end that goes into the VTC.they are JWT cams that came with the motor so I have no proof of purchase.
Can these be repaired or am I SOL?
Pix would be nice .....
Not understanding, are you building a 3.5 or just swapping or what? I'd say if the cam is cracked, you might be able to take it to a machine shop and see what they can do, but chances are it's toast.
I'm gonna see if they can do anything for me
if the cam is bent you will most likely need a new head unless the macine shop you go to knows how to work miracles but with an ohc setup it is very hard to get the cam journals perfectly straight again
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
