1997 vq20de cefiro
Old Oct 26, 2012 | 07:45 PM
keefeadsett's Avatar
1997 vq20de cefiro
i have a 97 cefiro with a vq20de in it and its idling rough and hesitating on acceleration. i started the engine and removed one coil connection at a time and found one tht didnt sound like it made a difference. i replaced that coil but im still having the same problems if not its got worse. any ideas on what my next step should be?
Old Oct 26, 2012 | 08:36 PM
schmellyfart's Avatar
Is the check engine light on? Are you up to date on maintainence?
Old Oct 26, 2012 | 09:06 PM
chrome91's Avatar
hook up a OBDII scanner and see if you can get any codes. otherwise, check your sparkplugs and see if you need new ones, and clean the mass air flow
Old Oct 26, 2012 | 10:35 PM
asand1's Avatar
Swap coils with another cylinder. If it follows the coil you need a new coil. If it stays with the cylinder do a compression test. Its gonna be spark, fuel, or compression.
Old Oct 27, 2012 | 12:51 AM
FallenOne's Avatar
Or ECM. But lets not jump to conclusions.
Old Oct 27, 2012 | 06:33 PM
thanks for your advice, i will definately change the sparkplugs and the fuel filter and also clean the air flow meter. will keep everyone upto date on the progress.
Old Oct 30, 2012 | 05:41 AM
catalinvint's Avatar
Do you notice excessive smoke coming out of the back when you accelerate? If yes then it's your MAF (airflow meter).
From the engine size you might be from Europe. Go to the Nissan dealer and ask them how much does a new MAF cost. If they want to rob you then go to a junkyard and get another one from a scrapped car.
Before doing all this be sure you clean you intake , airflow meter (MAF), change the fuel filter , oil and plugs would be a good idea.
Old Oct 30, 2012 | 11:57 AM
gidwits's Avatar
It sounds like one of the coils have gone bad hook up a obd2 and check the codes.
RinconI30
Jun 11, 2016 08:25 PM
RinconI30
Nov 10, 2015 10:55 PM
wiseguy6199
Sep 29, 2015 05:00 AM
ballerchris510
Sep 23, 2015 08:46 PM
Maxima Pride '07
Sep 12, 2015 07:29 AM
