Run without VSS?
Old Nov 1, 2012 | 12:56 PM
DBear's Avatar
Run without VSS?
I've got a kind of howling noise that sounds like it's coming from somewhere near the firewall, and varies weirdly with engine speed. It occurs to me the speed sensor might be the culprit. Can I run it with the sensor pulled to see if it goes away? I've got an AT. I assume the tranny fluid sloshes around some, but I don't have any sense of where the level is or how much pressure it's under. I'd probably tape over the hole but that obviously won't hold anything in.
Old Nov 1, 2012 | 01:03 PM
ShocknAwe's Avatar
its not expensive nor hard to replace it but I doubt you would be able to hear it. More than likely you hear your belt slipping. You do not want to run your engine without it as air will get in
Old Nov 1, 2012 | 11:25 PM
asand1's Avatar
http://forums.maxima.org/4th-generat...tion-idle.html
Old Nov 2, 2012 | 12:56 PM
DBear's Avatar
Thanks asand, I've been following that thread, since I think I have that too. But they're different noises.
Shock, I don't think it's a loose belt because it's much lower pitch than typical belt squeal, and I can't hear it over on that side. I may tighten the belts up though just to see, t hough. Since I hear it at idle, it didn't seem likely to be the VSS, but I'm grasping at straws here. I'll pull it just to check, but it's not likely enough for me to spend the $30 or so.
Old Nov 2, 2012 | 03:21 PM
Shift_A32B's Avatar
If you replace the VSS and need tips on how to remove it, read this link
http://forums.maxima.org/4th-generat...-pictures.html
New vss cost me $30.xx.
Comes with a new harness and the o-ring on it already.
captchaos
Mar 15, 2016 12:18 PM
junito1
Sep 23, 2015 12:14 PM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
ballerchris510
Sep 10, 2015 09:35 PM
