Tires losing air quickly...need new wheels?
Old Nov 3, 2012 | 06:56 AM
Chrono's Avatar
Hey guys, my 97 Max has been losing air in its tires quickly - I'd put in air at 38 PSI and then in like 2-3 weeks its dropping to like 14. I'm gonna get it checked out by discount tire, on the phone they said it's probably due to corrosion from the salt. What do you think?
I have YK580 tires, 16's I think. Can you recommend me some wheels and wheel brands? I don't know which company is good/bad. I like the 5 spoke design of the stock rims and want something similar..but a bit more cooler/modern looking.
Which of these would you get:
http://www.discounttire.com/dtcs/tog...id=006348&fcb=
Old Nov 3, 2012 | 08:30 AM
GGENIUS's Avatar
all four tires lose air pretty consistantly? seems like either dry rotted tires or ****ed up rims
Old Nov 3, 2012 | 09:52 AM
asand1's Avatar
How quickly has the air temp dropped outside? air pressure drops as air cools. Seems like that would be to much of a drop though.
Old Nov 3, 2012 | 10:19 AM
DennisMik's Avatar
It is highly unlikey that you would have 4 bad rims or 4 bad tires with some small pinhole in them. Probably the tire place is right.
Old Nov 3, 2012 | 11:15 AM
chrome91's Avatar
if theyre all losing air quickly, you just need your rims cleaned. the area where the rubber meets the rim will get corroded, and air will leak out. if you fill up one of your wheels with air and spray soapy water on the outer lip, you'll probably see air bubbles come from there
you just have to get the tires off and the edge of the rim grinded clean, and theyre good to go again. ive fixed hundreds of rims with the same problem, and some vehicles with all 4 losing air as well
Old Nov 3, 2012 | 11:58 AM
Trini Boom's Avatar
The tires may not have been sealed properly to the rims. Take it to a regular tire repair shop and they will fill it and out it into a tub of water to check for leakage and examine for rim damage.
Old Nov 3, 2012 | 12:14 PM
Shift_A32B's Avatar
I had the same problem recently with one tire. Turned out to have a small pinhole. I just had it patched up and problem solved.
Old Nov 3, 2012 | 03:50 PM
GGENIUS's Avatar
doubtful he ran over 4 pins strategically placed apart from each other.
02nissmax
Sep 5, 2015 01:50 PM
homeyclaus
Sep 3, 2015 06:15 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
twotonezed
Aug 16, 2015 11:41 AM
