3.5 swap timing
Old Nov 3, 2012 | 01:30 PM
Max streets's Avatar
3.5 swap timing
Im in doing 3.5 swap im about to put the outer timing case and see that the crank spocket isnt aligned with the cam spockets by what i mean is that my crank spocket further in the engine and the cam sprockets are further way from engine so when i put the chain on its doesnt prefectly straight looking at it from a side view.can any body tell me if this ok if not what should i do.im also using cam spacer tomei 264 cams.
Old Nov 6, 2012 | 07:23 AM
cardana24's Avatar
Blown
is the crank sprocket pushed all the way back? That one slides until everything is bolted down.
Old Nov 6, 2012 | 08:42 AM
asand1's Avatar
Is the sprocket turned around backwards? Idk what they look like, but if its offset and backwards? ?
Old Nov 6, 2012 | 03:33 PM
yeah thanks i found the problem i have to sets of spacers mismatch problem, but now what i see is that the spacers that i have are up side down meaning when i put the cam spockets the arrows face down both sets (spacers) are made this way.
schmellyfart
Sep 25, 2015 04:47 PM
FlaMark
25
Aug 28, 2015 10:15 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Blackwind
Aug 5, 2015 06:35 PM
