1998 maxima horn wont work when i press it
Old Nov 4, 2012 | 02:17 PM
Tevon Egdoh's Avatar
The horn on my maxima wont work when i press it, but if i trigger the alarm the horn sounds. the air bag light keeps flashing and the cruse control wont work either, ive tried to fiend a synatic of the steering assemby. but ive hit a wall here, how to fix it?
Old Nov 4, 2012 | 02:35 PM
GGENIUS's Avatar
everytime ive ran into horns not working on a car ive repaired, it was just because the fuse blew. check dems.
Old Nov 4, 2012 | 03:31 PM
asand1's Avatar
Your clock spring wire has broken. It Winds around the steering shaft many times and loosens or tightens as you turn right and left. aAl the switches, and the airbag run through this. Have you ever replaced the steering rack, or separated the steering shaft from the rack pinion shaft? If the steering wheel was turned independently of the steering gear and reinstalled, the clock spring could be wound too tight and broken. If a shop has done the above work recently you need to take it back and have them fix it.
It may also be as simple as a connector being unplugged.
Old Nov 4, 2012 | 03:38 PM
JNCoRacer's Avatar
Just the tip.
Originally Posted by asand1
Your clock spring wire has broken. It Winds around the steering shaft many times and loosens or tightens as you turn right and left. all the switches and the airbag run through this. Have you ever replaced the steering rack, or seperated the steering shaft from the rack pinion shaft. If the steering wheel was turned independently of the steering gear and reinstalled, the clock spring could be wound too tight and broken.
THIS. Or the steering wheel or just the airbag was removed and neither of the plugs were plugged back in.
Old Nov 5, 2012 | 04:22 AM
ryandaiber's Avatar
clock spring
scutmud
Aug 16, 2018 10:56 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
classymax420
Aug 6, 2015 06:35 PM
kenc15
Aug 5, 2015 08:29 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
