Engine idling problem
Old Nov 7, 2012 | 05:59 AM
Da4gotten's Avatar
My 99' Max when idling starts to jump or pump. You feel tiny bumps in the car, but only when the car is idling and on Drive. When I put in Neutral I don't feel it anymore.
My guesses would be since the other owner used premium gas all the time and since I got I switched to regular. But, Ive used premium to check if it still does that and it does. I also thought it would be sediment in the gas tank since it would let it get to empty most of the time but no.
Any guesses?
Old Nov 7, 2012 | 06:20 AM
njmaxseltd's Avatar
Most likely a misfire from weak or failing coil pack(s).
Old Nov 7, 2012 | 08:23 AM
ShocknAwe's Avatar
change the fuel filter and at least use mid grade. A good start
Old Nov 7, 2012 | 08:53 AM
Recarta's Avatar
Saving you trouble now. This is the problem. I replaced ALL the coils on my car just to end this problem ( and to know that everything was on top). Before you spend money on anything else check this.
Old Nov 10, 2012 | 09:28 AM
Da4gotten's Avatar
What could happen if I don't fix this soon? I don't have the cash to fix this problem. Could it damage my car?
Old Nov 10, 2012 | 09:43 AM
ShocknAwe's Avatar
You need to figure out the root of the problem first whether it be a fuel delivery issue, an ignition issue, or an air leak
Old Nov 10, 2012 | 10:27 AM
El_BoriMax's Avatar
Change your maf sensor. I replaced mine two days ago. I had similar problem. If I put the car on drive it will seem like im misfiring but idle was jumping and car shakes with it. When is on neutral or parking I wont feel it at all and the idle doesn't jump. Trust me
El_BoriMax's Avatar
I bought one on eBay for $45 down here in miami.
matts95max
Apr 23, 2025 10:44 AM
MAXSE5SPD
Sep 17, 2022 04:00 AM
boomerbrian
Oct 31, 2018 10:25 AM
TheMafia
Sep 4, 2015 08:26 AM
A32goldylocks
Sep 2, 2015 06:39 AM
