unloaded calipers
unloaded calipers
I ordered a set of unloaded calipers for my 98 Nissan maxima is there anything that I will need to buy before I install them? can I use the old mounting bolts?
Posted from Maxima.org App for Android
thanks, is there anything I should look for? this is my first time, I know I need to bleed them after, someone mentioned to me that they might require a special tool?
Fronts and back?
You'll need to bleed the brakes after the install. You'll need these supplies.
1) Brake fluid, 1 bottle should do it
2) Clear vinyl hose (Autozone should have) Should fit over the bleeder nipple
3) Someone to help you bleed the brakes or buy a vacuum bleeder kit
something like this
something like this
I meant the replacements, when he puts them on they probably wont yet be compressed. And I have no clue what its actually called I think i bought it as a piston compressor/rotator or something along those lines. They have it at all the local auto parts places and it basically is a cube with a 3/4 socket hole that you stick an extension in. There is a different pattern on each side for different cars so pick the one that applies and then the extension -> ratchet goes on the opposite side. I just did my brakes and had a hell of a time compressing those rears.
I just changed mine also. To be quite honest I was fine getting some ebay ones. They came in a set of 4x zinc coated slotted/drilled with 4x ceramic pads for like 190 or so. I haven't tried jamming the brakes yet but after bedding them they work fine for my every day driving.
Apr 16, 2020 05:15 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
