Side markers question
Old Jan 9, 2002 | 02:49 PM
kibic's Avatar
Can you guys tell me, the ones that put the sidemarkers in your fenders or wherever, how to hook them up so that they turn on with the parking light or with the head light, either one. I got the sidemarkers, but just need to figure out the way to hook them up.
Old Jan 9, 2002 | 03:20 PM
jdmmax's Avatar
Re: Side markers question
ok i just put mine last week.
you have to take of the plastic lining on the inside of the wheel well. (jack your car up so you have more work room)
-remove all the screws along the fender.
-remove the clips that clip the plastic that attach the liner to the
to the car.
-you do not have to take the inner liner out just move it out of the way so you can run wires.
-connect two wires to the side markers and tap those wires into the the side piece on the bumber lights.
done!!!!
thats how i wired mine do this to both side and you will be set.
oh and put a 10 fuse instead of the 7.5 that the factory uses.
cause you just added to more lights to the load. the fuse is the rear tail light fuse i think can't remeber.
Old Jan 9, 2002 | 04:06 PM
Supa Lao's Avatar
If you want the sidemarkers to blink alternately w/ the turn signal. Just tap into the positive of the turn signal and the positive of the factory side marker. I have that on mine, looks good
Old Jan 9, 2002 | 04:38 PM
Ramius83
What type of side markers are you all using? I am using these cheap ones that keep fading from clear to yellow on me. Thanks.
Cotozic
Feb 23, 2017 10:30 AM
vingodine
45
May 21, 2016 12:46 PM
papo99
Aug 9, 2015 07:32 AM
ZerotoSixty
Aug 6, 2015 04:34 AM
BassAddictJ
Aug 4, 2015 11:38 AM
