Fuel Pressure Regulator - Video or Guide?
Old Nov 29, 2012 | 03:09 PM
In2Deep's Avatar
Looking for a video or any other available guide to changing the fuel pressure regulator on a 4th gen maxima.
My issue is similar to many other maxima owners issues. If I don't start the car for more than a day it takes a few cranks to start it. As long as I start it every 12-15 hours it starts without issue.
Old Nov 29, 2012 | 04:08 PM
ATTappman's Avatar
Why would that be caused by the fuel pressure regulator? Is it leaking? To replace it, relieve the fuel pressure and then just remove it. Those two screws will be a challenge.
Old Nov 29, 2012 | 08:25 PM
In2Deep's Avatar
I don't know for sure that it would be the culprit. Just going by the hunch of a part time mechanic friend.
Old Dec 1, 2012 | 07:12 AM
Markusfisher's Avatar
I had the same problem twice. Once the vaccuum hose was torn. The second time the fuel line going to the FPR was slightly loose causing the fuel rail to very very slowly loose pressure after sitting. There is also a 90 cent o-ring which could be the culprit.
Old Dec 1, 2012 | 03:54 PM
In2Deep's Avatar
Thanks for the heads up. I'll check those out first.
Old Dec 1, 2012 | 06:45 PM
Trini Boom's Avatar
I don't think a video is needed for this as it is right in front of you as you open the hood. As for ruling this part out, if you crank your car and it starts up and dies right away, then the FPR could be the cause ONLY if you need to keep your foot on the gas to keep it on for a few seconds. If otherwise, your problem is somewhere else.
Old Dec 1, 2012 | 07:05 PM
ShocknAwe's Avatar
or it could be the coolant temperature sensor but usually then the starting problem only occurs when it is cold. Check your gas cap too. That keeps the pressure in as well.
Old Dec 3, 2012 | 03:58 PM
In2Deep's Avatar
If I start it once a day I have no issues. If I let it sit, it takes a few times to get it started.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
