synthetic ATF okay for auto???
Old Jan 9, 2002 | 08:32 PM
liloutlaws's Avatar
Is the synthetic ATF okay for an auto that has 70K miles? or should i just stick with dextron III?
also the dealer told me that i should change my ATF. I bet it has never been changed before and i'm at 70k miles. I was wondering if i frequently just do the drain and refill myself ..say every 5k miles until 80k. would that be sufficient enough? or should just go to the dealer and do the flush? wat do you guys suggest?
or should i try and do the flush myself? ..which is just basically draining..and then starting engine and drain some more while pouring until you have all new oil..correct?
Thanks a bunch. I will finally get my Max back from dealer tomorrow good and running =). Now just maintenance to go.
Old Jan 9, 2002 | 08:37 PM
HondaKiller718's Avatar
You should not have a prob just flush and refill with a synthetic.
Old Jan 11, 2002 | 09:04 AM
jayanth's Avatar
tranny
hey,
just see if it needs a change... a deep red fluid says "leave me alone!!!!
Old Jan 11, 2002 | 10:01 AM
caz41's Avatar
I would recomend synthetic ATF. I use Mobile 1 and love it. Also, if you drive a lot of miles, a trans cooler is not a bad idea.
Old Jan 11, 2002 | 10:15 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
http://forums.maxima.org/showthread....threadid=77101
mclasser
22
Nov 12, 2020 01:58 PM
AaronL
Aug 8, 2020 10:31 AM
Fbana41
Aug 29, 2016 12:18 PM
dshinn
Sep 26, 2015 08:07 PM
