Need help :(
Old Nov 10, 2000 | 10:54 PM
OgreDave's Avatar
I swapped out my TPS, it seemed to help for a bit. Car stalled today on the road, pissed me off. (2 or 3 times)
What would cause the car to drop down to ~490 rpms when im in first gear and breaking?
Then last time it stalled it straight up dropped to like 50rpms... kaput.
A totally different issue the car has is that sometimes when i step on the gas it takes a while for the car to start moving, then a whole bunch of torque is felt.. kinda like how people describe a highstall torque convertor.. think perhaps i need to clean mine out?
No clue. Just tired of this.
BTW, if the TPS helped for a lil bit, then cars doing this again... is there something like a recall on 4th gens for this? Last i checked 97's had no recalls. I've got an auto..
Thanks :> Hope to get this fixed n hookup some ECU & VB fun.
Old Nov 10, 2000 | 11:00 PM
Chunger's Avatar
My other car is a Hybrid
You changed a new TPS in your car already?
Why? Old one already dead?
Anyways.... most of them need to be adjusted properly (at least the old ones did...)
Try VBX Maxima site:
http://vbxmaxima.8m.com/tps.html
[Edited by Chunger on 11-11-2000 at 01:20 AM]
Old Nov 10, 2000 | 11:55 PM
mrloyd
sounds like fuel starvation to me. Change your fuel filter and check your vaccum lines.
Old Nov 11, 2000 | 02:29 AM
OgreDave's Avatar
how do i check them? i can change the fuel filter, that doesnt worry me. vaccum lines, i have no clue..
what else would happen if they (either part) was dying?
thanks, btw :>
Old Nov 11, 2000 | 02:30 AM
OgreDave's Avatar
Re: You changed a new TPS in your car already?
Yep, thats where i got the TPS thing. The car stalled worse b4. it was better for a while.. now its starting to get pissy again.
It was only like 54 bucks and uhh i stalled at school (while going into the turn lane as ppl were crossing) .. and power breaks went... that was the last straw. i forked out without even testing it, didnt care at that point.
Old Nov 1, 2008 | 07:06 PM
pschoggens's Avatar
Hi, great site, thankyou for your generosity of your time.
Quick question, if pin #1 from your write up, one the male plug furtherest from the drivers side has 0 volts does that mean there is a problem in the ecu? the car runs with it plugged in or not with very little change in rpms during the process, thought for sure it would throw a CEL. Only PO codes read from the reader is 0325 KS, 0120 TPS, and 1705 tranny or TPS which were cleared a few days ago and have not come back. car has 200k miles.
look forward to your response
Powell
Old Nov 1, 2008 | 07:26 PM
QNO_A32's Avatar
this is an old thread and all, but double check that you have the right pin.
Old Nov 1, 2008 | 07:47 PM
petro2342's Avatar
Wow! 8 years old!!! Never seen anyone revive a thread that old. Yikes!!
