white smoke+extreame gas out muffler+random miss fire.
Old Dec 23, 2012 | 11:30 AM
TravisCadello's Avatar
title says it all...it pure gas coming out my muffler bad random miss fires and smoke..maybe dropped a valve? 267,423 miles.
Old Dec 23, 2012 | 11:58 AM
Fakie J Farkerton's Avatar
Study your YouTube videos. Then, don't do that anymore. Future problems solved. I think there is a Honda out there for you. LHTD.
Old Dec 23, 2012 | 12:26 PM
DennisMik's Avatar
If you dropped a valve, I don't think that you would be driving the car anymore, you'd be looking for a new engine.
What you may have is a fuel injector that has stuck open or an o-ring on the tip of a fuel injector has failed. Pull the spark plugs and inspect them. The tip should be a tan color. One of the plugs will be wet from all the gas maybe even black in color.
But do something fast because all that raw gas will plug and destroy your catalytic converter in no time.
Old Dec 23, 2012 | 01:16 PM
the car is not bein drove it has maybe 50hp..all plugs r soaked wet and black
Old Dec 23, 2012 | 05:00 PM
what could it possibly be? i see my header collector seal is bad cuz gas comes out it like a 50psi fuel line. its DUMPING fuel into motor all 6 injectors
Old Dec 24, 2012 | 06:28 AM
aackshun's Avatar
This is not that hard to troubleshoot.....
I'll throw you a bone.
Remove your upper intake manifold.
Put the coil packs, back in the motor and plug them in.
Use shop towels (or rags) to protect all cylinders while you're working on the fuel rail assembly.
Remove the 4 bolts that hold them down and put a bag over each injector.
Have the car cranked over while watching what's happening w/ the bags, if you're alone just jump the starter yourself (signal wire to the B+ terminal) while the key is in the "ON" position.
Report results and everything you notice.... Hell make a crappy cell phone video, someone can easily tell you what's going on w/ the injectors.
If what I said sounded too technical, you shouldn't be fooling w/ this then, I am available to assist for a fee.
Old Dec 24, 2012 | 08:07 AM
well im a Mechanic myself, i just like extra information givin. i seen a chevy 350 do same thing as mine when the cam broke n half. with the miles on it i seriously thought it was a valvetrain problem but the heads are clean as heck no oil sludge what so ever thanks to mobil 1 past 30k miles.
anyways yes thats what i was gonna do today remove entire fuel rail and jump the starter see whats goin on. the fuel regulator isnt leaking fuel from vaccume line so i kinda dont think its the problem.
thanks buddy ill get back to ya later on today.
Old Dec 26, 2012 | 06:42 AM
DEVINEER's Avatar
Had the same issue with mine... I removed the upper intake and had my wife crank it and found the #3 injector stuck open spraying fuel like a water hose. Ill replace that this weekend and see how it goes. Check your injectors!
Old Dec 26, 2012 | 09:05 AM
Quickywd01's Avatar
Old Dec 26, 2012 | 01:20 PM
Nealoc187's Avatar
SLOW
OP is a mechanic? Holy Christ...
Old Dec 26, 2012 | 07:25 PM
renots's Avatar
Old Dec 27, 2012 | 05:28 AM
Trini Boom's Avatar
Old Dec 27, 2012 | 06:24 AM
njmaxseltd's Avatar
well im a Mechanic myself, .
This one time, when I was in band camp.
Old Dec 27, 2012 | 06:56 AM
cashoit's Avatar
Originally Posted by njmaxseltd
this one time, when i was in band camp.
lmao
Old Dec 27, 2012 | 07:30 AM
Quickywd01's Avatar
Because racecar.
Old Dec 31, 2012 | 09:22 AM
took it all off and as soon as i turned key n fuel presurised one injector was leaking massive ammounts of constant fuel without even crankin it. its fixed now.
shilov
Feb 19, 2024 09:40 PM
220k+ A32
18
Sep 22, 2015 11:39 AM
conansriver
Sep 16, 2015 12:17 PM
Maxxx10
Sep 13, 2015 03:16 PM
doctorpullit
Sep 10, 2015 06:33 PM
