95 GLE Noise Engine Right Side
Old Jan 1, 2013 | 04:14 PM
zoomer56's Avatar
Hi Y'all I used a rubber hose as a stethoscope to locate a grinding noise while engine is running. See attached file with blue arrow. Can you help identify this. It sounds like noise is coming from the panel the arrow points to. What is behind this? Could this be related to timing chain or the chain tensioner? Hard to tell without being there I know.
Old Jan 1, 2013 | 04:55 PM
ImpactR's Avatar
I believe that's the timing chain tensioner cover. Do you here this noise when the car is cold or warmed up?
Old Jan 3, 2013 | 05:35 AM
Trini Boom's Avatar
Timing chain tensioner access door. You have limited space there to replace it but it could be done with patience.
Old Jan 3, 2013 | 09:10 PM
max ride 41's Avatar
damn dude, dirtiest vq i've seen in awhile. i have a tapping when my 95's cold too, have since i bought it 8 years ago. i just make sure my oil's at a proper level, ( full ) and add a little bg moa oil additive. it helps keep the vq lubed and helps with seals, etc.
Hondarydr
Dec 30, 2024 06:15 PM
boomerbrian
Nov 8, 2015 05:10 PM
rtirbany
Sep 8, 2015 11:46 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
