p0444 evap
Old Jan 8, 2013 | 05:24 PM
notstreetlegal's Avatar
p0444 evap
I have the 440 code showing up on my 97. already replaced : charcoal canister,vent control valve,gas cap and still getting code. I know it could be several things so start shooting.
Old Jan 8, 2013 | 09:07 PM
DennisMik's Avatar
Here are things the service manual says to check.
Incorrect fuel tank vacuum relief valve
Incorrect fuel filler cap used
Fuel filler cap remains open or fails to close.
Foreign matter caught in fuel filler cap.
Leak is in line between intake manifold and EVAP canister purge volume control valve.
Foreign matter caught in EVAP canister vent control valve.
EVAP canister or fuel tank leaks
EVAP purge line (pipe and rubber tube) leaks
EVAP purge line rubber tube bent.
Blocked or bent rubber tube to EVAP control system pressure sensor
Loose or disconnected rubber tube
EVAP canister vent control valve and the circuit
EVAP canister purge volume control valve and the circuit
EVAP canister purge control solenoid valve
EVAP canister purge control valve
Absolute pressure sensor
Tank fuel temperature sensor
MAP/BARO switch solenoid valve and the circuit
Blocked or bent rubber tube to MAP/BARO switch solenoid valve
O-ring of EVAP canister vent control valve is missing or damaged.
Water separator
EVAP canister is saturated with water.
see page 226 http://boredmder.com/FSMs/Nissan/Maxima/1997/EC.pdf
Old Jan 9, 2013 | 09:25 AM
bobflood's Avatar
I ended up replacing all of the little valves/hoses on the bracket just in front of the cannister to get rid of my code. One of the nipples was cracked, but you couldn't see it because the short hose held it almost in place. I got the whole assembly from a local PullaPart lot and just swaped out the whole thing. Code has now been gone for a couple of years. Good luck.
Old Jan 9, 2013 | 01:25 PM
Smoke test revealed a steady stream from the little 3 inch pcv valve hose coming off the valve cover.Hopefully that was it.
tseng1023
Oct 15, 2015 08:30 AM
homeofbacon
Sep 23, 2015 07:17 PM
220k+ A32
Sep 11, 2015 02:18 AM
dcam0326
Sep 7, 2015 07:26 AM
doobadoo
Aug 15, 2015 06:43 PM
