rear koni shock help
On the rear shocks there there is a metal ring that comes with the spring perch. Were does this go?
That ring is all you need. You don't need those spring perches that Koni supplied. The rear GC collars have a groove machined out of the bottom and that rests snugly on the ring.
Are you using a ground control setup?
It barely slides over the strut body and rests on the notch of the strut. The GCs for Konis have this notch machined out that sits on top of this ring.
Violator
Sep 9, 2015 10:14 AM
