Bad Noise when started cold!?
Old Jan 10, 2002 | 09:05 PM
MaximaGTR311's Avatar
When I start my car in the mornings my engine make a horrible noise. The noise comes form the area where my timing drives are. Today somebody told me that maxima has timing chians not belts. The ironoc thing about that is it sounds like a loose chain, but the sound goes away after it gets warmed up. If anyone knows what it going on and can tell me how to fix it please let me know. This is driving me crazy.
P.S. This has inspired me to fix my old car (87 Mercury Lynx) and park the Max. Kind of a good thing.
Old Jan 11, 2002 | 06:52 AM
njmaxseltd's Avatar
Your timing chain tensioner may need to be replaced.
Old Jan 11, 2002 | 07:40 AM
timby01's Avatar
I get a high pitch sound when i first start the car coming from the left side while looking @ the engine is this the same noise u are talking about? I heard something about re-greasing the starter or something i gotta bring it in the get checked out
Old Jan 11, 2002 | 11:02 AM
nizmo's Avatar
Mine needs to be replaced ... is it safe to drive with this problem??
Old Jan 11, 2002 | 11:19 AM
GTRBlkMax97's Avatar
Re: Bad Noise when started cold!?
Originally posted by MaximaGTR311
(87 Mercury Lynx)
I was wondering if you were on here
Old Jan 11, 2002 | 11:20 AM
deezo's Avatar
Isn't this the starter noise that just about everyone gets when the car is in cold weather?
Old Jan 11, 2002 | 11:54 AM
Ndo125's Avatar
I have the same problem.......
Anyone...smart enough to answer?? =P
Old Jan 11, 2002 | 12:34 PM
95emeraldgxe's Avatar
there was a thread about this earlier this month, basically.....turn the key to the "run" position and wait a few seconds for the fuel injectors to engage and then turn it all the way. This may be a solution for some people, but maxGTR have have a more serious case possibly.
Old Jan 11, 2002 | 12:38 PM
95maxrider's Avatar
Lightly modded
I get a little harsh noise wheneven I start the car and its not warmed up. Should I get it checked out, or is this just another quirk of the Maxima?
Old Jan 11, 2002 | 01:10 PM
Ndo125's Avatar
It's a different problem......
the problem is NOT at the starting.......
the problem happen after it started........
Old Jan 11, 2002 | 01:45 PM
Xtreme5053's Avatar
Yeah, I have the high-pitched screeching noise upon startup, around the passenger side on the engine bay, has only been happening for the last few months, cold weather? I don't know, I should have it checked out. Need to get an O2 sensor anyways, darn "check engine" light.
Old Jan 16, 2002 | 03:08 PM
That's what I have but when I turn the key to on, let it sit for about 10 secs and it doesn't do it
Old Jan 16, 2002 | 06:35 PM
NYCe MaXiMa's Avatar
the high pitch sqealing noise is the accessory belts... I still get it... this is part of the 60k mile service. Examine them for cracks, check if it's too loose, it may just need to be tightened up. I greased them a little bit, also the tensioner pulley (i think that's what it's called) and it went away, then came back later on... It squeals for a while until it warms up to operating temperature.... then goes away......
Old Jan 16, 2002 | 07:09 PM
Autofanatic's Avatar
i think you have a tensioner problem...i have had this since i got my car a year ago, and yes it only occurrs when quite cold. i argued till i was blue with nissan mechanics about this problem (they had never seen one with the problem before, so they didn't beleive me..it was warm weather at the time, so i couldn't prove it to them).. the noise occurs for like 3 seconds after you start the car and then goes away. i think this is a VERY serious problem and would have it fixed if it weren't for the projected $1000 + price tag for repair...
if you have the money and this really is your problem, i think you should have the tensioner replaced...
just my 2 cents
Old Jan 22, 2002 | 12:43 AM
neutron's Avatar
Mine has a faint noise sounds like the chain. It is periodic and sync with RPM, no matter cold or warm. There is a TSB about 95-96 max timing chain noise.
Old Jan 22, 2002 | 02:27 AM
carnal_c30's Avatar
Former Sponsor
some of that high pitched squeal could be water on the belts... thats what I suspect, ever since my CF hood, some water gets on the belts when I rinse my car and now the belts squeal for a few seconds then stop
tsi6001
Oct 3, 2022 10:23 PM
maxinout93
Oct 27, 2015 01:29 PM
FlaMark
25
Aug 28, 2015 10:15 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
