Something rubber in one of my valves?
Old Jan 16, 2013 | 06:43 PM
delacruz_17's Avatar
SOLVED: Something rubber in one of my valves?
I did a valve job and now it starts very weird :
Try 01:
Try 02:
After doing try 02 I think something is in one of my valves. Sounds like a piece of rubber. What do you guys think?
Old Jan 16, 2013 | 06:48 PM
Climaxx's Avatar
In the first vid; I can hear a noise, hard to tell exactly what/where it is, but sounds like it goes away after a few cranks? And is it catching and then dying? Or are you turning it off?
Old Jan 16, 2013 | 06:58 PM
its turning off 100% on its own. I am about to get borrow a compression tester but not sure exactly what to look for in my situation. Any tips ?
Old Jan 16, 2013 | 06:59 PM
maxgtr2000's Avatar
KH3 by popular demand
Recheck your timing but it might be too late. The first noise sounds like the timing chain noise like after you change the water pump before it regains tension, the 2nd vid didn't go long enough to hear the sound, but whatever the case your car seems to take a long time to start which is not good. Is this the first valve job you have attempted?
Old Jan 16, 2013 | 07:30 PM
Thanks guys for the input. I just fixed this issue. The problem was that i embarrassingly forgot to connect coil packs 1-3-5. Ones I connected the three the car started up. Heres a video:
Old Jan 16, 2013 | 08:02 PM
Climaxx's Avatar
Take it for a drive. Let it warm up and then see if the noise goes away. Tighten up that belt and put on a small amount of belt dressing.
Old Jan 16, 2013 | 08:20 PM
max ride 41's Avatar
no, no belt dressing. just adjust the tension on the pulley. your timing's way too high and i still hear clacking from the chain. make sure your oil level's on the line and your coolant and tranny fluid are filled up too.
Old Jan 16, 2013 | 08:42 PM
What exactly do you mean the timing is too high? On the video I have the 00vi mod stuff on but I removed the Greddy emanage blue computer yesterday in order to troubleshoot my car not being able to turn on. Since it turns on now I will install the Greddy emanage blue computer tomorrow.
The two belts are brand new:
Gates K040305 Multi V-Groove Belt
Gates K060431 Multi V-Groove Belt
Since they are both new I will just adjust them both tomorrow. The noise should go away on its own.
Thanks everyone for the input.
Old Jan 16, 2013 | 10:27 PM
if you altered the ecu with the emanage and it's unplugged, maybe thats what im hearing. sounds like the idle is a little high. also, make sure you don't overtighten the tension, maybe too tight now.
Old Jan 17, 2013 | 05:41 AM
njmaxseltd's Avatar
Why did the engine require a valve job? Did a reputable shop do the machine work? Who shimmed it, the shop or you?
Old Jan 17, 2013 | 08:27 AM
I did the valve job. None of the decks were warped. I checked all the valve clearance with feeler gauges. No adjustments to the shims were required. I lapped the valves with a lapping stick.
As to why I did a valve job. I had time to spare and wanted to give my car a longer life.
Some images of the valve job I did:
After lapping:
After lapping:
After lapping:
This is how it looked when I removed for the first time the front valve cover.
How I installed the valve keepers:
Cylinder heads removed:
Gasket kit ($87.99) I used while doing the valve job:
Last edited by delacruz_17; Jan 17, 2013 at 08:30 AM. Reason: Added info on the gasket kit I used while doing the valve job.
Old Jan 17, 2013 | 11:32 AM
njmaxseltd's Avatar
Thumbs up for the DIY work!
As far as giving it more life, it they weren't leaking, the job wasn't necessary and isn't going to give your engine more life. What will give it more life is good maintenance.
Old Jan 17, 2013 | 03:42 PM
Well to be honest it was leaking oil and burning oil too:
shilov
Feb 19, 2024 09:40 PM
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
tardrex
Sep 11, 2015 07:35 PM
