Vibration - something other than tires/wheels?
Old Jan 29, 2013 | 02:18 PM
BobMax's Avatar
Looking for some general info on those that know these cars better than me :-)
Test drove a '98 auto with < 100K miles. Ran nice, but there was some light vibration while moving. My first thought is wheels/tires, but it didn't come and go at various speeds, it was just kind of there. I know a tire & wheel change to balance would be the first thing to check, but it's not my car and I can't do that before buying. So, I need to make an intelligent guess.
Is this at all typical on these ? Are there any parts that tend to wear that would cause vibration? axles maybe? Something else? Anything I can check without having it on a lift and all to my own?
Thanks,
Old Jan 29, 2013 | 04:56 PM
GGENIUS's Avatar
Thanks,
wheel bearing... but your description isnt very detailed. also these questions your asking can be answered with a little searching, as always...
Old Jan 30, 2013 | 12:33 PM
BobMax's Avatar
Thanks... unfortunately I don't have a lot of details since I haven't been able to get the car on a jack.
Are wheel bearings much trouble on these? Do you need to pull the strut? Press needed?
Thanks,
Old Jan 30, 2013 | 01:20 PM
maxed_out_99's Avatar
yeah the bearings are pressed in. its may be a chalange on the ground with hand tools.
i would run the car in drive on a rack and look at both axles. there should be no movement
Old Jan 30, 2013 | 03:23 PM
BobMax's Avatar
As in zero play end to end on the axle, or zero play left and right and up and down going into the CV & tranny? Or both?
If there is play... does it just get worse and worse until you fix it, or does the axle snap one day 'cause you did something foolish like waiting for warmer weather to do it :-)
Old Jan 30, 2013 | 03:48 PM
njmaxseltd's Avatar
Need more info.
Does the vibration happen at a specific speed or all the time?
Is it rhythmic or random? Can you duplicate it and if so how?
Does it happen when your accelerating or braking?
Does it happen in neutral, revving the engine?
Is the idle smooth, is the check engine light on, DOES IT WORK? (Light when the key is turned to the on position)
Old Feb 1, 2013 | 11:53 AM
BobMax's Avatar
Originally Posted by njmaxseltd
Need more info.
-Seems to be at all speeds
-consistent, like driving on slightly rough pavement (halfway to the feeling you get when they just ground the road for resurfacing - but only halfway there).
-when moving, did not appear to be braking related ( no real change when brakes applied, no apparent braking issued like warped rotors)
- does not seem to be there at idle or revved ... seems to be motion related
- no CEL, checked codes with reader, none pending, all monitors ready
Thanks,
Old Feb 1, 2013 | 05:47 PM
Climaxx's Avatar
Wheels/tires/suspension isn't really my area of expertise, but if I were to guess; cv axle, wheel bearing like previously stated, and/or lower control arm(lca)/ball joint. You CAN buy new lca's with ball joints already pressed in. If you get them make sure to get an alignment afterwards. Might as well get your wheels balanced too.
Old Feb 1, 2013 | 11:33 PM
maxima2fst4u's Avatar
my passenger side cv axle made mine vibrate the half way shaft like bearing deal that has three bolts to hold it in place the bearings in mine caused mine after i spent money on some wheel bearings lol needed them anyways
Old Feb 6, 2013 | 09:11 PM
BobMax's Avatar
Thanks... I'm closing the deal on it this week. I'll swap the wheels/tires, see where that gets me, do some inspection and test runs, and come back with questions.
user 11122324
42
Jul 18, 2022 03:35 PM
HOKUSMAX
Nov 13, 2017 04:34 AM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
06maxima55
Sep 28, 2015 04:29 PM
Bonka
Sep 14, 2015 11:18 PM
