replaced alternator , battery and brake light flash with rpms,light dim, hesitation
Old Jan 31, 2013 | 11:18 PM
dannie123's Avatar
I replaced the alternator in the maxima because the battery died the old alternator was.not tested, neither was the alt. Determined to be problem..
Anyways
I replaced the alt. And it was fine for a day and then the next day the brake and battery light flash with RPMs (at about 35003500) instead of being lit before the alt. Replacement.
I tested the voltage at the battery and it read 14~16 volts
When the car is revved the lights dim as well.
Also At about 4000RPMs it hesitates
Please.any help.is.appreciated what could.it be if.net the alternator
Old Feb 1, 2013 | 02:18 AM
What year Max do you have? If a 99, it could be the coilpacks causing the hesitation issues your describing.
Re-check battery, re-check alt.
Old Feb 1, 2013 | 06:33 AM
Trini Boom's Avatar
Always start with the basics in mechanics. Start your car with accessories off and remove positive wire from battery. If car dies right away, alternator is your issue and if it does not, get your battery tested.
Old Feb 1, 2013 | 07:35 AM
Wholebrooks's Avatar
Make sure your batt ground isn't loose. You just replaced the alterntor and didn't have these problems before, right? Go back and check everything you did to replace thealternator.
Old Feb 1, 2013 | 09:29 AM
DennisMik's Avatar
That alternator you put in is FUBAR. You stated you get up to 16 volts. You should NEVER get 16 volts. Replace that alternator.
Old Oct 1, 2019 | 01:18 PM
Roymg's Avatar
Not sure that's a good idea to remove the battery from the circuit. Use a good testor to ck the alternator output at the battery while connected.
Old Oct 1, 2019 | 02:29 PM
KP11520's Avatar
^^^^^^^^^^^^^^^^^THIS, THIS, THIS, THIS, THIS, THIS, THIS, THIS, THIS, THIS, THIS, THIS, THIS, THIS, THIS, THIS, ^^^^^^^^^^^^^^^^^^^^^^^
Too much voltage can do a job on anything electronic. including your ECM.
And we've been seeing a lot problems with new and rebuilt garbage being sold. Hitachi rebuilts seems to be the best bet for Alternators.
Old Oct 1, 2019 | 06:10 PM
wxm's Avatar
wxm
Originally Posted by wholebrooks
make sure your batt ground isn't loose. You just replaced the alterntor and didn't have these problems before, right? Go back and check everything you did to replace thealternator.
+1
Old Oct 1, 2019 | 07:49 PM
reallywildstuff's Avatar
six year old thread
Old Oct 2, 2019 | 09:06 AM
Roymg's Avatar
Originally Posted by reallywildstuff
six year old thread
Always good to have more information that can help no matter when its given.
maximaham
Jun 21, 2017 07:21 PM
hithesh
Oct 27, 2015 10:15 PM
h2kFrosty
Jan 10, 2015 12:12 PM
Nmax92
42
Aug 27, 2010 01:47 PM
racin89lx
Jul 2, 2006 07:46 AM
