Battery/alt.charging issue
Old Jun 21, 2017 | 05:37 PM
maximaham's Avatar
Hi i noticed to day when i wet to start my car its was only charging at 11.52 volt so i also checked it with my multi meter and it says the same thing. question is.
Is my alternator about to go.
Old Jun 21, 2017 | 05:48 PM
97_GXE's Avatar
I don't know much about voltage, but I do know if you're alternator goes out...the battery light and brake light will stay on. Sometimes it'll die right away, or it'll wait 250 miles into a trip and die on you in the middle of nowhere. True story.
However, I had some scares where my brake and battery light would remain on right after starting up. Turning car off and restart usually clears it. I recently cleaned and regressed the cables, that seems to have helped with my start up issues.
Old Jun 21, 2017 | 05:59 PM
maximaham's Avatar
Ain't that the truth
Old Jun 21, 2017 | 07:21 PM
DennisMik's Avatar
If the voltage is 11.2 volts, the alternator is not GOING out - it has ALL READY gone out.
Afully charged battery will measure 12.5 volts, give or take. When the alternator is charging, the voltage reading will be about 14.2 volts.
Any voltage below 12 says that the alternator is not working and you are running off of the battery and discharging it.
