Tire size and MPH changes
Old Feb 18, 2013 | 02:44 AM
busterbrown1's Avatar
After installing 2001 SE wheels (225/50/17) on my 98 GLE, I noticed a roughly 2.0 mph difference on the speedometer vs the GPS speed on my Torque application. OEM size was 205/65/15) This is much larger than originally anticipated. Tire size calculators showed a 1.4% slower speed on the larger tires which translated into a 0.9 MPH difference on the speedo (at 60 mph).
Do I have any options in correcting this difference (ie tuning the ECU)??? My 06 SUV has a PCM that was tuned to do just that).
Old Feb 18, 2013 | 06:50 AM
EvoTillIDie's Avatar
It's been asked many times before & truthfully as far as I know the only way to have your speedometer corrected is to get the gauges itself redone which I believe cost a lot of money + they wouldnt be OEM looking..which is one reason why I dont wanna rush to get rims....I love knowing my correct speed...
Old Feb 18, 2013 | 07:21 AM
UniqueMax's Avatar
If you good with disassembling and assembling things then it should be pretty easy-risky lol.take off front cover of speedometer and pull off the MPH needle. Drive on freeway and put it on cruise once you hit 60mph(check ur GPS for speed or course).While doing 60,put the needle back in.All set.
Old Feb 18, 2013 | 07:24 AM
UniqueMax's Avatar
Other way to do it is if u lift up one front end tire.Jack it up and do same thing.Only difference is that the cruise won't stay on(since one tire its not rotating),and its kinda hard to keep it constantly on 60.It'll feel like if you're revving it on park..with a little vibration of course from tire rotation
Old Feb 18, 2013 | 07:28 AM
max ride 41's Avatar
retarded and unsafe, and those needles are'nt easy to pop on and off like that they're very fragile. when i did my indiglow gauges it took me awhile to set those back on there straight. and dude, i've had 17 inch wheels for like 3 years and had 15's for years before, the difference is so small it's not worth stressing over it. but you allready know that.
Old Feb 18, 2013 | 07:44 AM
UniqueMax's Avatar
Yes Mom it IS retarded.Sorry I wont do it again.I have tried your way and it takes MUCH longer to get it right.[Stop,pull needle out,put back in,drive] x (who knows how many times to get it JUST right]=.
GM vehicles have it simple.I have done at least 20 clusters on GM trucks/cars and its pull and push back.
Anyways to get it safer(if you're doing the freeway thingy),get a friend to put needle back while you steer
Old Feb 18, 2013 | 07:57 AM
ABIGBRAIN's Avatar
Please stop typing....
Old Feb 18, 2013 | 08:12 AM
ShocknAwe's Avatar
OP, use this http://www.miata.net/garage/tirecalc.html
The difference is minimal for most applications and with the wide variety of aspect ratio's available you can put on rims up to 18" and still have an accurate speedo
Old Feb 18, 2013 | 09:11 AM
cjanderson3's Avatar
These guys are awesome, This might solve your problem
Old Feb 18, 2013 | 09:46 AM
asand1's Avatar
That's the dumbest thing I've ever heard. 60 MPH would be the only speed that was correct. Above and below that would be wrong.
Old Feb 18, 2013 | 11:26 AM
UniqueMax's Avatar
Please stop reading.....
Old Feb 18, 2013 | 11:41 AM
UniqueMax's Avatar
The difference is minimal for most applications and with the wide variety of aspect ratio's available you can put on rims up to 18" and still have an accurate speedo[/quote]
Anyways yea..difference is minimal.Don't beat yourself up over it
Old Feb 18, 2013 | 11:45 AM
UniqueMax's Avatar
RIPTIDER
Wheels/Tires
Jan 31, 2016 07:39 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
Bonka
Sep 14, 2015 11:18 PM
