Need a high output alternator
Old Feb 20, 2013 | 07:05 PM
kwilliamsdude's Avatar
Does anyone know of any sites that sell high output alternators for 1995 Nissan Maxima v6?? Im in need of one real bad! Please and thank you!
Old Feb 20, 2013 | 07:31 PM
I need around a 200-250amp HO alternator
Old Feb 20, 2013 | 07:35 PM
BlackThornDemon's Avatar
The only alternators I've seen are the OE 110 amp (California models) and 130 amp (federal models).
lol
Why do you need 200+ amps?
Old Feb 20, 2013 | 07:39 PM
Fakie J Farkerton's Avatar
Maybe this belongs in the audio and electronics thread?
Any good audio shop can build whatever strength alternator you want.
I have a NAPA 200amp that works fine with my 750RMS audio amp, but I have an upgraded battery also.
~and that 200amps comes at 2,000 rpm.
Welcome to the org.
Old Feb 20, 2013 | 07:50 PM
I have a 1500rms amp that im about to hook up to 1 ohm and im pretty sure that my Max's alt will not be able to handle it. Sorry its not in the Car audio part..Im new to this site
Old Feb 20, 2013 | 07:55 PM
Yeah, general recommendation is anything over 1000 amps get a stronger alternator or capacitor.
Old Feb 20, 2013 | 08:03 PM
I have a tsunami litewave series pp92 2 farad capacitor that im gonna use but i want the full power of my amp though so i really need a HO alt. im just having trouble finding one
Old Feb 20, 2013 | 08:25 PM
Honestly, I have a 500 watt sony sub and a 500 amp. Never heard a reason to go bigger.
Old Feb 20, 2013 | 08:35 PM
theres a big difference in 500rms and 1500rms
Old Feb 20, 2013 | 08:49 PM
max_dreamer's Avatar
both the maximas and the i30's had a 200amp and 160amp alternator option i believe. ive seen them around. ebay has um. ive seen a couple in jy's but never needed them so never thought to pull um. There was some thread here that had the color codes for the power outputs. i believe they are red or green.
Old Feb 20, 2013 | 08:54 PM
Yeah they have a 250amp alt. on ebay for 230 bucks but that just doesnt sound right. Pretty low priced for 250amps. I wonder if it actually does the 250amps....
Old Feb 20, 2013 | 09:05 PM
asand1's Avatar
I've heard you can only get 50-75 dependable extra amps without enlarging the frame. Murano and Quest alternators reportedly fit and put out ~150A.
It may be possible to rewind a quest unit for 200-250A.
Old Feb 20, 2013 | 09:13 PM
I really need atleast 200amps If i had to go lower id possibly go 180...idk why it has to be so complicated to find one...
Old Feb 20, 2013 | 09:18 PM
I don't need a nuclear powerplant to power mine.
Old Feb 20, 2013 | 09:19 PM
DennisMik's Avatar
All you have to do is go to Google and type in "high amperage alternator" and you will get results like this:
https://www.dcpowerinc.com/vafproduc...3.0L+V6+VQ30DE
This one is nice because it has high output at idle. A lot of other alternators have to be at a higher rpm.
Old Feb 20, 2013 | 09:20 PM
ShocknAwe's Avatar
I would just have one made. 1500rms in a 4th gen....thats a bit overkill but dont cheap out on an alt or you will regret it
Old Feb 20, 2013 | 09:26 PM
The ones you posted are super expensive though. I wasnt looking to spend 600 bucks on an alt. i was looking towards 3-400
Where would I just have one made??
Old Feb 20, 2013 | 10:38 PM
Maximeltman's Avatar
Schtooops
Old Feb 20, 2013 | 10:40 PM
Old Feb 21, 2013 | 06:04 AM
NABU6's Avatar
Try these -
http://mechman.com/
http://www.excessiveamperage.com/
Old Feb 21, 2013 | 06:41 AM
Thanks Ive already received quotes from Mechman and dcpower and both of them were gonna cost me 600+ and I dont really wanna spend that much. I just asked for a quote on on excessiveamperage....maybe theyll have better prices. Thanks
Old Feb 21, 2013 | 09:19 AM
Climaxx's Avatar
seriously, good luck finding anything cheaper than that.
you gotta pay to play.
Old Feb 21, 2013 | 09:52 AM
tigersharkdude's Avatar
Old Feb 21, 2013 | 10:26 AM
S1cTech's Avatar
You don't need an HO alt. Just get more batteries. Take it from me. I have a 2200watt RMS high end system. You may need to replace the stock alt maybe after 5 years but HO alts are just bad for the electronics in your car. Expensive as hell and have premature failure more than a stock one. Also the fact that you can't change it out and put it into another car.
Old Feb 21, 2013 | 10:45 AM
So you think I should just get more batteries??
Old Feb 21, 2013 | 11:36 AM
asand1's Avatar
Wrong. Think of a battery as a water tank. You still need a pump large enough to keep up with demand. Doesn't matter if you have 50 batteries, the alt will commit suicide trying to keep up, and never keep the batteries fully charged. Id give the alt a month or two to live.
HO alts for Maximas don't come cheap because there is a low demand. Now if you found a Honda unit that fit you might get it cheaper.
Old Feb 21, 2013 | 11:40 AM
^^Well said.
Old Feb 21, 2013 | 12:13 PM
Thats what I thought....Im having a hard time finding an alt round 3 or 4 hundred eveyone wants 650+. Does anyone know of any cars alternators that are interchangeable with the 19995 nissan max?
Old Feb 21, 2013 | 03:07 PM
catalinvint's Avatar
Try excessive.amperage@gmail.com.
The link was posted by another member , http://www.excessiveamperage.com/ , his name is Nathan. I got mine from him in December. Works like a charm and no more electrical issues.
Old Feb 21, 2013 | 05:07 PM
I just emailed them. The best offer Ive gotten was from SInger and it was 439 bucks for a 250amps alt. Plus he includes an overdrive pulley to boost the idle output (this will spin the alternator faster at low RPMS to boost idle output by around 30 to 40A more then the stock will).
Old Feb 21, 2013 | 06:21 PM
Climaxx's Avatar
^ which means you'll need to find a larger belt
Old Feb 21, 2013 | 06:47 PM
how big of a belt? and can I use a deep cycle battery for under my hood? If so what are some brands that are good? besides optima yellow top. I know about them.
Old Feb 21, 2013 | 09:55 PM
DennisMik's Avatar
I'm pretty sure the alternator pulley will be smaller than the stock one. Maybe the belt tensioner will be able to take up the extra slack in the belt, maybe not. You might have to get a smaller belt.
FYI - the stock belt is 43.5 inches.
Old Feb 21, 2013 | 10:08 PM
one person is saying bigger another saying smaller???
Old Feb 21, 2013 | 11:09 PM
Max streets's Avatar
1500 watts u dont really need high output alternater get ur self yellow top battery u can ether have it as an extra 1 which will work better than cap that will run for about 220 and voltage stablizer razin for about 60 to 80 bucks or if u want to use the yellow top up front get a amp cap cell (soundstream) with those three things u wont get any light dimming i have those 3 things on 6000 watts of bass. and it doesnt dim unless i crank to about 5000 then i would recommend a high output alternater that run for 6 to 700 bucks u choose.
but with those 3 things i mentioned its only about 500 bucks.and ull good with that.
u wanna check high output alternaters check here.
www.dcpowerinc.com
Old Feb 21, 2013 | 11:56 PM
Well i think ive figured everything out. I can get a Singer HO alt. 250amps and 150 at idle for 439 and get a XS Power battery for 125. So itd be about the same amount of money as you are telling me but thanks though.
Old Feb 22, 2013 | 05:53 AM
NABU6's Avatar
I know Mechman alt. was offering a deal were if you purchase a alternator and XS power battery at the same time, you received a 10% discount. Dont know if this is still going on, but you should call them and ask. I havent heard that much info regarding Stinger alt.( not saying there good or bad) but the two that I heard alot about when researching HO Alt. is Mechman and DC power.
Old Feb 22, 2013 | 07:38 AM
Its not Stinger its Singer Alternators. So when I do get my HO alternator do I need to replace my battery up front or what?
TallTom
57
Oct 14, 2025 05:16 PM
maxinout93
Oct 31, 2015 02:04 AM
