Starting problems
Starting problems
So for the past 2 months my car hasn't been starting regularly, and it started first when it was cold and now it never starts, but no click no sounds, and all lights turn on, car beeps, andradio turns ion but car doesn't crank. I checked battery, alternator, and starter and they are good but car does not start when turning it on with the key, and only when I bypass the ignition. any suggestions?
Try to wiggle key...if it cranks then it ignition switch. About 30 bucks and 20 minute install. Try pushing shifter into park further when turning key...if it cranks then its neutral switch. If starter is older and you have been cranking the **** out of it lately.....change starter or at least get it tested.
sctludwig
Sep 1, 2022 01:32 PM
trungg86
Sep 4, 2015 04:58 AM
Ignore this post.
and
you.
