Engine bogs when clutch is pressed
Old Jan 11, 2002 | 07:13 PM
cjrj473's Avatar
Often, when my car has been in the same gear at a constant speed for more than 30 seconds or so and i press the clutch, the engine rpms will drop to 300-400 or so for a moment, like it is going to stall, and then returns to the normal 600-700. At the same time the dash fan will slow down, but the lights do not dim and the radio stays the same. Is this abnormal/serious, or should i not worry about it? My fateher's truck does not do this.
Thanks, Chris
P.S. I searched but didnt find anything about this specific occurrance
Old Jan 11, 2002 | 07:26 PM
Scruit's Avatar
U wanna try me young boy?
Re: Engine bogs when clutch is pressed
Thanks, Chris
If you near-stall the engine the electicals will appear to dim. I would try to rule out battery/charging problems first, but then return to the Throttle Body and Idle Air Control Valve to ensure they are properly able to handle the rapid change from high RPM to idle.
Do you have the same cold-start near-stall problem that a few of us have been having? If so, clean the black soot from around the butterfly in yor Throttle Body. Do a search for some instructions. This may be the cause of both, as the cold-start near-stall and drop-to-idle near-stall both relate to the car's ability to idle smoothly without relying on the Idle Air Control Valve.
Old Jan 11, 2002 | 07:31 PM
Sprint's Avatar
http://www.motorvate.ca/auto/maxima/...y_cleaning.htm
Old Jan 11, 2002 | 07:56 PM
cjrj473's Avatar
i cleaned the tb 6-7 months ago, so i would think that it is still in good shape. ill have to take a look at the idle air control valve, what should i look for?
Old Jan 11, 2002 | 07:58 PM
cjrj473's Avatar
oh yeah havent had any problems with cold starts whatsoever, which surprised me cause i went from ky to indianapolis, my car isnt used to the cold here
Old Jan 11, 2002 | 08:15 PM
Sprint's Avatar
http://forums.maxima.org/showthread.php?threadid=83805
Old Jan 11, 2002 | 08:17 PM
Sprint's Avatar
clean it again just to make sure.. i cleaned mine 2 months ago.. but didn't do it properly .. it temporarily fixed the problem.. but its back.. tis time i am going to use a toothbrush
Old Jan 11, 2002 | 08:22 PM
cjrj473's Avatar
looks like i need to get a manual and check this stuff out. thanks for the help.
Old Jan 11, 2002 | 08:31 PM
cjrj473's Avatar
just noticed something esle- my k&n drop-in is getting kinda dirty. could this be causing the problem? it has only been in there about 10k miles, i thought that you were supposed to clean every 50k? ill give that a shot tomorrow and see what happens.
Old Jan 11, 2002 | 08:33 PM
Sprint's Avatar
let us know...
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
BkGreen97
Apr 2, 2016 05:47 AM
cruce91
Sep 20, 2015 10:23 AM
seesole
Sep 14, 2015 12:38 PM
