99 max installing FSTB(vibrant) why don't I have to cut the bracket?
Old Jan 11, 2002 | 07:50 PM
costcowholesale's Avatar
the tiny driver side bracket thing, I didn't have to cut anything, it just went right in, look here
http://communities.msn.com/mycarniss...ma/maxima.msnw
did I get the wrong FSTB?
Old Jan 11, 2002 | 07:53 PM
Nismo's Avatar
no cutting here also
Old Jan 11, 2002 | 08:07 PM
but 99+ max got those bracket things there, & a lot of peopel told me they have to cut the bracket thing off I dunno
Old Jan 11, 2002 | 08:08 PM
araffio's Avatar
why would you have to cut anything???
Old Jan 11, 2002 | 08:18 PM
http://forums.maxima.org/showthread....ght=streetbeat
Old Jan 11, 2002 | 08:31 PM
JUDE's Avatar
I just got my FTSB today for my 99. So if I understand from previous posts, since its a Courtesy bar, I don't have to worry about the bracket, right?
Old Jan 11, 2002 | 08:39 PM
I have no idea, Nathan had clearance problem from his 99, I didn't have that problem from my 99, we both have vibrant (street-beat)FSTB. I think you're fine because they mentioned courtesy bar will clear
Old Jan 11, 2002 | 08:50 PM
JUDE's Avatar
I was going to wait to install it next week. My car needs an allignment and I thought it would be better to get that first before installation. What do you think?
Old Jan 11, 2002 | 11:58 PM
Bman's Avatar
I think it's your guys' cars that are different in not needing to cut the bracket. I bought my Courtesy 5th Gen FSTB from Sterling99SEL, who didn't like the fit, and he bought a Courtesy 4th Gen bar instead. He DID have to cut his bracket, but he sent me a picture of it and the bracket on his car looks different from yours and sits higher. It's like an inverted Y squished down onto the strut, and looks like it would almost certainly interfere with that FSTB, since the C-bracket on the Courtesy FSTB looks almost identical.
I'm guessing then that the bracket is one of those mid-production run changes manufacturers sometimes make.
Mystery solved!
Old Jan 12, 2002 | 12:15 AM
ny96max's Avatar
cutting to fit a FSTB is def a first for me
Old Jan 12, 2002 | 12:44 AM
1MAX2NV's Avatar
I guess that's the difference between..
plain 99 and the 99 SEL
Old Jan 12, 2002 | 05:47 AM
Vyrus's Avatar
Re: I guess that's the difference between..
Exactly. The '99s should have no problem at all. The '99SE-L does have to cut a bracket.
-Cyrus
Old Jan 12, 2002 | 06:16 AM
playas33's Avatar
I have a '99 GXE and had to cut the bracket, I got mine from custommaxima.com....don't know what brand it is?
Old Jan 12, 2002 | 08:54 AM
mine is an early 99 model (brought it October 98)what about those that had to cut the bracket? maybe thru middle of hte year nissan moved the bracket up
Old Jan 12, 2002 | 05:18 PM
ok, I think it has to do with early & late 99 model, my early 99 model doesn't have the big bracket thing that late 99 models have. Take a look madd max's late 99 & my early 99
late 99 :
http://community.webshots.com/storag...upQZYCs_ph.jpg
http://community.webshots.com/storag...IjkUJTN_ph.jpg
early 99(mine):
http://community.webshots.com/storag...xeeUdyz_ph.jpg
http://community.webshots.com/storag...VNpCAsu_ph.jpg
http://community.webshots.com/storag...vxkhlmb_ph.jpg
Old Jan 12, 2002 | 07:31 PM
Synki's Avatar
Yep. I have a late model 99 GXE and have the braket there. I have test fitted a FSTB and realize i had to cut and never ended up getting a FSTB since i didnt want to cut it
Old Jan 12, 2002 | 07:49 PM
u still don't have it?? you're afraid of cutting the bracket there & not using nitrous
j/k
Old Jan 12, 2002 | 09:00 PM
Maxilicious's Avatar
99 SEL
I have a 99 SEL with a courtesy FSTB. I had to cut. Very simple and made a dif in handling. If you cut.... paint the exposed metal so rust will not develop.
Old Jan 12, 2002 | 09:45 PM
1MAX2NV's Avatar
I think it probably has to do with production date?
and not purchased date? Who has the earlist production date for a 99? Mine was made in 12/98. I bought it 03/99.
Old Jan 12, 2002 | 09:48 PM
Re: I think it probably has to do with production date?
I purchased mine 10/98 so mine gotta be one of the earlier ones. How do I check production date?
Old Jan 12, 2002 | 10:19 PM
Synki's Avatar
Originally posted by costcowholesale
u still don't have it?? you're afraid of cutting the bracket there & not using nitrous :laugh
j/k
What nitrous?
I have it, just havent installed it yet. I need to fix the dremel.
Old Jan 13, 2002 | 04:39 PM
1MAX2NV's Avatar
Re: Re: I think it probably has to do with production date?
Check the plate that's on the door jam when the driver door is open.
dank4us
34
Jun 10, 2024 03:45 AM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
schmellyfart
Sep 25, 2015 04:47 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
