Performance upgrades
Old Mar 1, 2013 | 02:25 PM
jaeazy's Avatar
so im trying to debate on swapping a 3.5 with 6spd tranny in my 4th gen since there more aftermarket support (but heard it a pain in the A$$ and cant find a full write up ion how to do the full swap) or keep my 3.0 and build that?
but havent found much of a support in finding aftermarket upgrades, please help want to make reliable 450whp
also have to replace flywheel due to 1336 code chipped flywheel
so if 3.5 swap is better rather wait and do that then spend the money on another clutch and flywheel
PLEASE HELP!!!!
Old Mar 1, 2013 | 02:38 PM
maxgtr2000's Avatar
KH3 by popular demand
400hp requires boost. You can stay 3.0 and boost it or 3.5 swap+boost. If you have the money you can do whatever.
Old Mar 1, 2013 | 06:33 PM
neosmatrix's Avatar
Boost or Juice!!!
Best of luck
S
Old Mar 2, 2013 | 04:21 AM
jaeazy's Avatar
ok where can i find aftermarket performance parts like pistons connecting rods cams etc for boost build on the 3.0? Problem is cant find enough aftermarket support
Old Mar 2, 2013 | 08:47 AM
UniqueMax's Avatar
I saw a pic of a member from here.He dropped a 3.5 on a '97 and supercharged it.He claims 407 whp
Old Mar 2, 2013 | 12:15 PM
carsnwomen91's Avatar
I know akeems maxima from Canada (street outlawz) is 350+ whp on stock 3.0 with 00vi and supercharged at 12 psi. You can use 3.5 heads on a 3.0 to have lower compression and boost a lil more
Old Mar 2, 2013 | 12:47 PM
maxima.713's Avatar
Build the 3.5 and slap it in with the 3.0 timing. You can keep your 5speed just get a better clutch done deal.
Old Mar 2, 2013 | 12:52 PM
RA030726's Avatar
I'm nutty for Nissans
There is really no point in building a VQ. Stock motors with the right bolt ons make plenty of power to destroy transmissions or drive shafts. FWD cars don't make the best of high horsepower. 300 FWHP is more than enough.
Your best engine options are:
VQ30 with 00vi
VQ35 with VQ30 timing
Get headers
TUNE!!!
I wouldn't bother with a 6 spd either.
As for your CEL code, the flywheel has a timing ring on it. The flywheel is probably fine.
Old Mar 2, 2013 | 03:16 PM
CMax03's Avatar
I'm itchy to do this as well.....for my 98! I'm just short on time and money....but I have the skill to do it!
Old Mar 2, 2013 | 08:50 PM
How did you come up with the magic number of 450hp?
Have you ever been in a FWD car with that much power?
Old Mar 3, 2013 | 05:55 PM
Fauken's Avatar
Listen to this man, he isn't a wizard for no reason.
Old Mar 3, 2013 | 06:09 PM
litch's Avatar
don't be ichty, get litchy! for serious mang, frank may be up for sale soon, no need to spend da scratch, get a new whip!
Old Mar 3, 2013 | 06:18 PM
T_Behr904's Avatar
A friend of mine has a built VW Golf pushing about that, and it's completely worthless without slicks.
Old Mar 3, 2013 | 06:31 PM
CallMeThatOneGuy's Avatar
I have a full 3.5 swap ready to go, just no time for it hopefully spring break.. and yeah 450hp needs some rethinking.. for street use and street "applications" you should stick to a lower number...
Old Mar 4, 2013 | 01:06 AM
maxima.713's Avatar
If civics can do it so can maximas lol
Old Mar 4, 2013 | 08:40 AM
jaeazy's Avatar
yes i have i owned a eg hatch b20 vtec turbo and was pushing 416whp
Old Mar 4, 2013 | 08:45 AM
jaeazy's Avatar
VQ30 with 00vi
Get headers
TUNE!!!
heard that the 3.5 matted to 5spd tranny is bad for the tranny from wat ive read in some of the discussions
300whp would be nice as well just cant find a supercharger for it ive been looking
Old Mar 4, 2013 | 09:03 AM
litch's Avatar
heard that the 3.5 matted to 5spd tranny is good for the tranny from wat ive read in some of the discussions
3.5 matted to a 5spd tranny is veddy naice... dis what my max has... if you want 300 whp there are ways to get it without fi... but the amount of money you would spend on cams, pistons, itbs, e85 conversion...etc... you could just buy a supercharger and get there cheaper...
Old Mar 4, 2013 | 10:09 AM
Can't find a SC? There's several in the classifieds.
Old Mar 4, 2013 | 12:14 PM
RA030726's Avatar
A 4th gen would run 3.0 timing therefor the Stillen SC will fit a 3.5 swapped into a 4th gen.
Old Mar 4, 2013 | 04:59 PM
maxima.713's Avatar
No with nitrous it will be cheaper...
Old Mar 5, 2013 | 06:37 AM
jaeazy's Avatar
whats the beat 00vi setup for great gains,because there are several options???
Old Mar 5, 2013 | 07:18 AM
max1008's Avatar
Doing the full 5th gen OOVI swap (injectors, LIM, fuel rail, 5th gen TB or Pathfinder TB, and 4th gen IACV). Or you can do what I'm doing and get a full DEK swap for pretty cheap. Then sell parts off your DE motor or sell the DE all together.
Old Mar 5, 2013 | 12:10 PM
Personal preference. End hp result is the same.
Old Mar 5, 2013 | 12:33 PM
litch's Avatar
Yes, I mis-spoke (mis-typed??) nitrous is always, 100% of the time the biggest bang for your buck...buuuuutttt, its only there when you pusha-da button, sc is all the time... but you are right sir.
Old Mar 5, 2013 | 02:22 PM
jaeazy's Avatar
How much for the full de-k swap
Old Mar 5, 2013 | 02:36 PM
shaks's Avatar
it's whatever you pay for the engine plus time or labor to swap it in
you'll need a street tune with vafc to have better results
there are engines local to me for 400 in good condition, 100k on them
Old Mar 5, 2013 | 04:41 PM
jaeazy's Avatar
Old Mar 5, 2013 | 06:12 PM
BlackThornDemon's Avatar
Why swap the 3.5 and keep the 3.0 timing?
Old Mar 5, 2013 | 06:15 PM
litch's Avatar
duuuuuuuude....
because thats how you swap a 3.5 into a 4th gen...unless you are suratt....
Old Mar 5, 2013 | 06:16 PM
I get that. Everyone says keep the 3.0 timing. But, no one says why.
Old Mar 5, 2013 | 06:22 PM
litch's Avatar
Ok, here we go.
1: Its not a honda, you cannot just go full wiring harness, ecu, gauge cluster swap, it doesn't work, I personally spent over 4k trying to make it happen, it can't unless you are a wiring genious.
So our option is to do a hybrid swap, where we "trick" the car into thinking there is nothing different with the engine, this is accomplished by leaving all the timing components (read: the stuff that makes the engine run) and adapting them to the 3.5 block. There is a guy on here who makes the adapters, you can also get them from JWT.
Basically you take out the 3.0 block leave the oil pans/timing in tact, apply the timing chain adapters, which require intimate knowledge of the timing chain system, then install the 3.5 block. With this done your car's ecu will not think that anything is different since all its sensors (for the most part) are still reading everything just fine. You can delete the vias, and the egr with block off plates from NWP, and get some spacers from them while you are at it to bump the hp of the 3.5 up quite a bit.
Old Mar 5, 2013 | 07:36 PM
maxima.713's Avatar
Less of a hassle...
Old Mar 6, 2013 | 12:39 PM
RA030726's Avatar
VQ35 engines have variable cam timing. The 4th gen has no way of controlling this.
It is far easier, and cheaper, to swap the timing components than it is to do a full ECU swap. NATS for instance, its a *****.
Can you get a full running 3.5 into a 4th gen? Yes. If you are asking if it can be done, then you most likely do not have the means to get it done.
Old Mar 6, 2013 | 02:09 PM
jaeazy's Avatar
3.5
ive read some things saying that the 3.5 engine matted to the 5spd isnt good for the tranny
Old Mar 6, 2013 | 05:06 PM
MAXIMA_STYLE's Avatar
Altima 3.5 comes in 5 speed stick.so think again
Old Mar 6, 2013 | 11:42 PM
maxima.713's Avatar
If you dont go cheap on the gear oil or get an over agressive clutch then you will be fine! Trust me i learned the hard way lol
Old Mar 7, 2013 | 03:44 AM
kenc15's Avatar
it amazes me how people wanna do big jobs on their car but are too lazy to research or read. I was the only guy in jacksonville man enough to take on a two 4g63 swaps in a mirage because I read and did my research while the majority of people paid to have a shop do a basic b18 swap in a civic.
Old Mar 7, 2013 | 07:02 AM
jaeazy's Avatar
hooray for u, guess wat im doing the swap (im a tech at a dealership) and have done many before, im new to the nissan scene, and have questions about the right power plant. If u dont have any encouraging things to say or help dont comment iight & also if the threads werent so old wen ur looking stuff up 75% of these repeat question wouldnt arise,sir
Old Mar 7, 2013 | 07:09 AM
jaeazy's Avatar
oh ok thanks
