Timing cover question?
Old 03-03-2013 | 11:45 PM
anthony18's Avatar
So my 4th gen max is leaking oil around the lower oil pan / timing cover I know for sure it's not the sending unit I leak about 5 qt every 2 weeks a serious problem but my question is do I have to change everything in my timing cover if I just open it up to reseal it with RTV or will have to buy water pump, guides, Tensioner ect the car was a rebuilt salvage idk when the water pump or guides, tensioner was replaced.
Old 03-04-2013 | 12:55 AM
shaks's Avatar
once you are there - it would be much easier to do everything to avoid trouble in the future. it's up to you as that will burn a little hole in the pocket
if you are leaking that much - you don't have to change your oil I assume (cruel joke)
Old 03-04-2013 | 09:02 AM
Climaxx's Avatar
^ I think that's that new "self changing" oil. Lol
Op; you do not have to replace anything except for the rtv if you take the timing cover off. However, it would be wise to replace atleast the water pump o rings and tensioner. At the very minimum I would do the o rings. (Like $7-8 a piece from dealer)
Can't go wrong with preventive maintenance. Especially in the timing cover cuz it by itself is so labor intensive.
Old 03-04-2013 | 01:23 PM
catalinvint's Avatar
I just had the same issue. It was not leaking that much but still. The seal between the oil pan and timing cover need to be replaced. You can buy the entire seal kit and do it all , it's around 20 bucks. If you have the money it's better to do it all(chain, oil pump , water pump) now since it's open.
Old 03-04-2013 | 04:59 PM
anthony18's Avatar
Ok why I ask the question is because I getting 2013 honda in 7 months and I just don't wanna burn a hole in my pocket to fix a problem then get rid of the car I love my max to def was my fist car tons of memories but ill go the replace what should be replaced I'm going to sell the car but it's not going to a person the car will be put out of commission
maxprivate
Forced Induction
21
07-08-2017 10:48 AM
max_speed97
08-26-2015 08:46 PM
MaximaDrvr
08-19-2015 09:20 PM
Team STILLEN
08-10-2015 05:29 PM
BassAddictJ
08-04-2015 12:38 PM
Quick Reply: Timing cover question?
