help.. car used to be auto and its been swapped for a 5-spd..(not by me)
Old Mar 4, 2013 | 04:15 PM
blackmaxi99's Avatar
Hey guys.. I grabbed this car for a decent price.. but anyways.. I was told it was an auto and it was switched to 5-spd.. and it has a ses light on.. havent checked it yet to see what code but thats what I was told its on for from the previous owner.. car runs mint and starts fine.. has no issues.. my problem is I have to go through emisons with it and i cant with the ses light on obviously.. and again I havent checked the code nor tried to clear it yet.. but my question is.. is there a step by step write up on how to fix the problem? I like doing things myself and would rather do it myself than have to take it to a shop.. Thanks in advance!!
Old Mar 4, 2013 | 04:42 PM
Climaxx's Avatar
There is more than likely a how-to to fix whatever issue you may on here. But you're gonna have to find out what's causing it first.
If you have some mechanical skills there's a how-to in the stickies that shows how you can extract the code directly from the ecu... Or you can go to your local autozone and they can tell you for free lol
Old Mar 4, 2013 | 04:58 PM
Nissanserguy's Avatar
you need to fin out what code it is. I'm guessing it's for the reverse position switch though.
Try this, put your keys in the ignition, turn but don't start, make sure handbrake is all the way up, put car in reverse and hop out and see if your reverse lights work.
I knew a guy that had done the auto to manual swap and that was his problem
Old Mar 4, 2013 | 05:37 PM
no my reverse lights dont work..
Old Mar 4, 2013 | 05:52 PM
asand1's Avatar
I'm surprised no one has made a harness to connect the manual trans position switch to the Park/Neutral connector. Also, to clear all codes you will need to replace the auto ECU with a manual trans ECU.
Old Mar 4, 2013 | 06:38 PM
search around on here, I know there are alot of guys on here that have done the swap, see if there was a solution to the problem.
And
+1 to asand1
Old Mar 4, 2013 | 06:44 PM
Try these posts, see if anything will help.
http://forums.maxima.org/4th-generat...ard-p1706.html
http://forums.maxima.org/4th-generat...tions-how.html
Old Mar 5, 2013 | 02:50 AM
another thing.. I dont need to touch the clutch to start the car..
Old Mar 5, 2013 | 05:29 AM
njmaxseltd's Avatar
Hope you got a good deal on it...
Old Mar 5, 2013 | 05:44 AM
cjanderson3's Avatar
This guy may have done the mechanical parts correctly, but electronically the car still thinks it is an auto. No reverse lights, no clutch safety to start it, the car has no idea that your swapping gears instead of it. Definitely read through those suggested threads word for word suggested above
Old Mar 5, 2013 | 01:12 PM
asand1's Avatar
This is not such a bad thing. I modded my stock 5spd max so that I don't have to press the clutch or worry about the clutch interlock relay or the theft warning system working.
Manual transmission cars were built without clutch interlock systems for 80+ years. It wasn't until the '80s that the government thought they needed to protect us from starting in gear.
Lakersallday24
Jun 16, 2019 01:35 AM
maxima-junky
Oct 21, 2015 05:17 PM
maxima-junky
Aug 13, 2015 09:59 AM
Blackwind
Aug 5, 2015 06:35 PM
