ecu questions
Old Mar 5, 2013 | 04:47 PM
MAXIMA_STYLE's Avatar
ecu questions
Ok guys..long story short.. I bought a 99 with a 97 fed motor... Obviously the 99 is cali and the pin out is slightly different... Rather than repin it i was considering swapping the engine harness out with a 97 fed harness.. It would eliminate wiring just straying around the bay... Anyhow..someone told me due to my nats system if i swap the engine harness and ecu with a 97 it will NOT work and that my car would need the dash harness relaced as well... I know Aackshun is the master at this wiring crap... Anyone else know how much truth there is to this?? Is it safe to say i can buy the 97 fed harness and swap it out and run a 97 ecu with no problems??
Old Mar 5, 2013 | 05:24 PM
njmaxseltd's Avatar
I believe the 97 ECU will eliminate the NATS.
Old Mar 5, 2013 | 07:16 PM
DennisMik's Avatar
Some of the pin connections in the 99 ECU were different from the 95-98 ECU. The Cali-Fed stuff wasn't the reason.
I have a list of the ECU pins for all the 4th gen years with the differences highlighted. It is a PDF file and I don't know how to post it here. If you want it, I'll e-mail it to you if you pm me with your e-mail address.
Old Mar 5, 2013 | 07:45 PM
ABIGBRAIN's Avatar
I PM'ed you for the PDF as well.
Andy
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
junito1
Sep 23, 2015 12:14 PM
Socalstillen
Sep 20, 2015 11:46 PM
QueensMAX
Sep 15, 2015 04:14 AM
