Foglights not working due to?
Old Mar 11, 2013 | 02:15 PM
4DGA32's Avatar
So my 98 max didnt come with fogs just the wiring, i installed fogs last night, got the switch from a 2001 Infiniti I30, fuse was already there, and installed a relay. Turned on the car and only the left side was working ( headlight, and fogs). BUT the right side fog wasnt working at all including the headlights, corner lights.
I was using a half dead battery .. maybe thats the cause? or maybe its the switch?
Checked everything on the right side, all bulbs and connectors are properly in.
Any suggestions?
signals dont work also !
tried on my OLD switch, and only the left side headlight is on... maybe its the battery?
Old Mar 11, 2013 | 02:38 PM
BlackThornDemon's Avatar
Its not the battery. If it was then your lights would be dim, all of them. Its probably not going to be the switch or relay. It sounds like the wiring is messed up.
Old Mar 11, 2013 | 03:01 PM
4DGA32's Avatar
The lights were dim, even the dome light in the car.. and
pretty sure the wires wont be messed, because my car came with the wires OEM already because my headlights were perfectly before, until i plugged the foglight connector to the I30 switch.. ill check for both connectors, and the wires.
Old Mar 11, 2013 | 03:13 PM
4DGA32's Avatar
UPDATE*
i dont hear my relay clickin when i turn on the fogs .. been searching and it says that it should click.
Old Mar 11, 2013 | 03:17 PM
GGENIUS's Avatar
i didnt know the stalk from a 2001 infiniti works in our cars.
Old Mar 11, 2013 | 03:20 PM
The lights will be dim with a weak battery. But, the battery wont turn on some lights and not others.
You have separate circuits for the headlights, fog lights, turn signals/hazards. So the only way for your right side and turn signals to not work is if:
1) there is no ground present
2) something in the wiring or switch is touching or otherwise shorting the fogs out between the other circuits
3) fuse (for the right side only, doesn't explain turn signals/hazards)
http://www.nicoclub.com/FSM/Maxima/1998/EL.pdf
Old Mar 11, 2013 | 03:22 PM
Originally Posted by 4DGA32
UPDATE*
According it the fsm there is only 1 relay for both fog lamps. So if 1 works, the relay *should* be fine. But, you can swap it for another relay of the same type to make sure. I think the anti-theft relay is the same (don't try and start the car without it though).
Do you have your center dash apart? Specifically the portion with the hazard button? The turn signals wont work without it (or if the car's not on).
Old Mar 11, 2013 | 05:47 PM
4DGA32's Avatar
OH i forgot to mention the hazard lights work.
Old Mar 11, 2013 | 08:57 PM
DennisMik's Avatar
I think it is most likely the Infiniti headlight switch. It has one more position than the 4th gen Maxima. It has the AUTO position next to the OFF position. It is not the same switch as your 98 Max needs.
Old Mar 14, 2013 | 05:33 AM
4DGA32's Avatar
Ohh opps, i knew it was the switch, when i installed it at first it was acting up. Ill get back at you once i get another switch
Old Mar 14, 2013 | 08:19 AM
Amerikaner83's Avatar
yes. Get a switch from a 4.5 gen Maxima like you should. Specifically, the 97-99, as (at least with the variable intermittent wipers) the switch is different than the earlier 4th gens.
Frankly, I am also surprized that the switch even fit properly.
Old Mar 14, 2013 | 04:14 PM
4DGA32's Avatar
Hey so it was the switch after all thanks for the help man!
Old Mar 16, 2013 | 09:54 AM
GGENIUS's Avatar
^ i called the switch out in my post in this thread...
Old Mar 21, 2013 | 09:50 PM
4DGA32's Avatar
thanks to you too! haha
rbuswell
Nov 17, 2016 04:54 AM
bk2k3max
Sep 17, 2015 09:39 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kenc15
Aug 5, 2015 08:29 AM
