View Poll Results: Want a LCD Gauge Cluster?
Voters: 39. You may not vote on this poll
Interested in LCD Gauges?
I would hope you mean the other way around. The OEM analog RPM gage is woefully inaccurate. Ask anyone with a VAFC, Summitt or any other rpm switch.
They're going to be a mix between analog and digital. See the picture here.
I will also need to probe some cars pretty soon. The process should take about an hour. Hook some stuff up. Drive around. Record resurgent. Probees will get a discount
PM me if you're interested. I need both 5spd and autos.
On my car when I tilt the steering all the way down, I wind up never seeing the indicator lights. Your diagram looks OK with the indicator LEDs a bit lower, but if you could make sure all the important lights are still visible no matter how the wheel is tilted, that would be nice.
update
I little snippet of some progress.
Code:
// Created by BlackThornDemon
// See desc.txt for more info
#include <Adafruit_GFX.h>
#include <Adafruit_PCD8544.h>
#include <avr/pgmspace.h> // memory management
#define cel_height 48
#define cel_width 84
Adafruit_PCD8544 lcd= Adafruit_PCD8544(3,4,5,7,6);
// globals
// dummy lights
// use byte because its 8 bit (int, short, etc. are 2 bytes)
// array is in THIS order:
// abs, airbag, battery, brake, brights, cel, cruise, door open,
// left turn, over drive, oil, right turn, seatbelt, washer fluid
byte dummyPins[13] = {22,23,24,25,26,27,28,29,30,31,32,33,34,35};
// Gauges
// MAX input is 3.3V
// ^^^^^ --REMEMBER THIS IT MATTERS-- ^^^^^
byte pinFuel =0;
byte pinSpeed =1;
byte pinTach =2;
byte pinTemp =3;
// Mileage
// this is some cool ****
// we're actually saving the odometer and trip
// to the built in flash memory so it gets saved
// NOTE: this method may never actually get used
// as the developers estimate the built in memory
// can only be accessed about 100,000 times
// in all actuality nobody probably ever starts a car
// in its whole lifetime 100,000 times much less a car
// that's 14-18 years old already however in the sake
// of longevity I will explore other options of saving
// data (such as a SD card)
int trip =0;
int odometer =0;
/* processing of on/off lights (i.e. abs, brake, etc.)
void dummyLight()
/* this is the base of the dummy lights
if the input is 0-0.49 the light is read as OFF
if the input is 0.50-1 the light is read as ON
void CheckSignalDigital(int signalPin, int max)
// read the pin here so we don't have to read it 4 times
float pinValue = digitalRead(signalPin);
if(pinValue >= 0.50 && pinValue <= 1)
// this is important because if the light was previously on
// we need to turn it off
else if(pinValue >=0 && pinValue <= 0.49)
else PinReadError();
boolean CheckSignalAnalog()
void PinReadError(string pin, string error)
// print the error on screen nicely
void setup()
odometer =;
lcd.begin();
lcd.command(PCD8544_DISPLAYCONTROL | PCD8544_DISPLAYNORMAL);
lcd.clearDisplay();
lcd.setContrast(60);
lcd.setTextSize(2);
lcd.setCursor(0,0);
void loop()
for(int i=0;i<13;i++)
CheckSignalDigital(dummyPins[i], 1);
lcd.display();
delay(100);
More progress. Right now I'm looking in to making a can bus/obd board to keep the cost down.
Woot! free samples
http://www.obdsol.com/stn1110/
Woot! free samples
4th gen obd is very very very very slow
you should buy a obd reader and see how the rpm's correlate to the gauge when you rev before you go too far(im not sure if our obd port shows the speedo?)
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
