Question for those running with a 5th gen throttle body and iacv
Old Mar 14, 2013 | 02:49 PM
whitemax21's Avatar
I recently did a complete dek swap. I am having an issue with the idle when I come to a stop. The rpms dip to around 400-500 rpms, causing the car to almost stall. I increased the idle by adjusting the screw on the throttle body and this helped some. After almost stalling out, the idle is fine. Any suggestions for correcting this issue? I am using the throttle position sensor from the 4th gen. If the tps was out of adjustment, could this cause this issue? I just removed it from my old engine and attached to the 5th gen.
Old Mar 14, 2013 | 05:15 PM
maxima2fst4u's Avatar
it could have some affect on it when i replaced my tps i had to tweak with it to get it back in align with the old that was on it cause i just bolted my new up and went and had that issue but im not running the dek swap....but figured it all the same anyways you know
vingodine
45
May 21, 2016 12:46 PM
Finkle
Sep 27, 2015 09:53 PM
homewrecker
Aug 24, 2015 08:56 PM
Samedi
Aug 13, 2015 04:05 PM
