codee help
Old Mar 14, 2013 | 07:48 PM
P0tter7's Avatar
codee help
p1447- evap canister purge flow/volume control valvr circuit
to start off i dont got much time to get into this hole my car throwing codes right now i have zero time for sleep. so i got zero time to work on my car hoping monday i free up alittle.
wat my car is doing is, it like cuts out. not the elrtical stuff but like as if the fuel was cut out and back on. and it dose it like 6 time then goes away. an there isnt a cetain time it dose it like when its cold, or after driving for an hour, or when i jump on it. i could be at a set 50 mph and it will do it. i can jump off at a light and it will do it.
i had these codes to start off with when it was doing it( p0400- exhaust gas recirulation flow. p0301- misfire cylinder 1.) so i changed the plug in that cylinder and also switched the coil to a diff cylinder to see if the misfire changes. so i cleared the code and drove it. didnt do it the hole night of driving it. then it did it again. i checked the codes the next day it came up with p1447- evap canister purge flow/ volume control valve circuit.
i think its an evap leak. also i was talking to a guy i work with and he said an evap leak shouldnt make it cut out like that. me and him are going to look into when we arent swomped a work. sorry its so long just figureed i would get it out now so u guys no all the details.
thanks guys.
Old Mar 14, 2013 | 11:51 PM
BIG D MAXX's Avatar
Check fuel pump and connectors
Old Mar 15, 2013 | 03:14 AM
2brosgixxer's Avatar
Are you still showing the misfire code? It wasn't very clear if the misfire code is there along with the EVAP. EVAP will not cause the car to cut out but the misfire definitely will. If you replace the coil, USE OEM NISSAN ONLY!!
Old Mar 15, 2013 | 03:31 PM
P0tter7's Avatar
i have a part car so i got coils from that. the misfire isnt there anymore. sorry about that. the fuel pump is my next step. but for it to throw and evap leak code. dont make sence
i wanna fix everthing so when i do my motor swap i no everything was ok from when i started and i no it what went wrong.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
