clutch went flat and shifting was denied...
97 5spd.
the other day the clutch went flat after i went to restart the car and it wouldn't go into gear. started it in gear and the clutch came back after about 30 seconds.
any thoughts?
any thoughts?
check the lines... most likely the joint connection on the top of the transmission is busted... very common problem with the spaghetti mess of lines on the hydraulic systems of the maximas...
If it is a hydraulic line that is broken, replace it with a direct flexible stainless steel braided line between the master and slave and eliminate all of that intermediate plumbing. I got one on-line for about $40 from racetechperformance.com. Make sure you order the correct one - they have one that just replaces the lower flexible portion, and one that replaces both the flexible and hardline sections. Good luck.
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
