97 maxima vehicle speed sensor
Old Mar 20, 2013 | 03:25 PM
TurboA32's Avatar
Has anyone ever changed the speed sensor on a 5spd and the speed doesn't work right away? I changed my speed sensor because I had a code for it and the sensor would work but not right away so I got a new one from autozone and it seems like its the same.
Old Mar 20, 2013 | 06:52 PM
TurboA32's Avatar
Just warmed up the car and drove and the speed meter was working. Parked the car and turned it off for a few minutes then went for a drive again then wasn't working but after a few minutes it was working.
Old Mar 20, 2013 | 09:34 PM
2brosgixxer's Avatar
Have you checked your wires? It almost sounds like something may be a little loose causing an intermittent connection.
Old Mar 20, 2013 | 11:46 PM
TurboA32's Avatar
I'll have to check that and get back to you
Old Mar 21, 2013 | 01:47 AM
Thats the only thing I can think of since it seems to work after driving for a bit. It leads me to believe that maybe wires are moving around causing it to start working. Member DennisMik is great with electrical stuff and could probably help you. Shoot him a PM if you don't make any progress.
Old Mar 21, 2013 | 12:03 PM
cjandura's Avatar
do you have a CEL and a P0500 code?
Old Mar 21, 2013 | 12:19 PM
EvoTillIDie's Avatar
We have the same problem! I changed my VSS even though I didn't have the code hoping it would fix the problem but it didn't....Sometimes the speedometer works & sometimes it doesn't...I think the odometer too
Old Mar 21, 2013 | 12:32 PM
schmellyfart's Avatar
Check the wires behind the gauge cluster.
Old Mar 21, 2013 | 12:36 PM
99NightRiderMAX's Avatar
Change your gauge cluster, takes maybe 20 minutes to do. Get it from a junkyard or ebay. I had the same problem with my 97 I30
Old Mar 21, 2013 | 01:31 PM
cjandura's Avatar
Ok here is the dix that worked for me i took out the speedo head removed all the philips screws cleaned all the contacts under the screws with a nail file on both the speedo head and the flex circuit and i have not had the problem return i had a internintant 500 code flashing light 13x on startup and no cruise control and now it works btw evil the 500 code will cause you to fail inspect/emissions just so you know
Old Mar 21, 2013 | 05:45 PM
TurboA32's Avatar
I had a code and I dont have a light on anymore after I reset and changed the sensor but now I have no light
Old Mar 21, 2013 | 05:48 PM
TurboA32's Avatar
Yea thats why im trying to solve this problem because I have emissions due soon
Old Mar 21, 2013 | 05:50 PM
TurboA32's Avatar
When I let the car warm up the speed meter works
Old Mar 22, 2013 | 02:24 PM
TurboA32's Avatar
I changed the wire and still the same
Old Mar 22, 2013 | 05:41 PM
I'm leaning toward this now too. Find someone on the ORG or a junkyard who has a cluster and swap the whole thing out. If the VSS is not the issue, really the only other thing is the gauge cluster itself.
Old Mar 22, 2013 | 07:09 PM
TurboA32's Avatar
I changed the speed cluster and it worked on the first cold drive but ill see if it still works the next time I have to drive
Old Mar 23, 2013 | 12:22 PM
TurboA32's Avatar
It was the speed cluster. Now it works every time thanks guys
mrc00l88
Jan 25, 2024 01:14 PM
09maxshawn11
Aug 14, 2015 10:07 PM
Team STILLEN
Aug 10, 2015 04:29 PM
