Car heat smells like burnt glue, wet engine
Old Mar 27, 2013 | 09:36 PM
ookami85's Avatar
When I turn on the heat I smell glue. I lift the hood up and the engine area looks wet(Where those 6 pipe looking things are in the middle of the picture). What's going on? I attached a picture so you guys can see what I'm talking about. Hope you guys can help!
Attached Thumbnails Car heat smells like burnt glue, wet engine-img_0591.jpg
Old Mar 27, 2013 | 09:49 PM
2kMaxim's Avatar
Im thinking you obviously have a large coolant leak....maybe a busted hose and you are smelling coolant.
Old Mar 27, 2013 | 10:01 PM
Calden__003's Avatar
huh, that explains the look of my engine as well
Old Mar 27, 2013 | 10:02 PM
ookami85's Avatar
WHere would it be coming from? is it a expensive fix?
Old Mar 27, 2013 | 10:05 PM
DennisMik's Avatar
Those tubes are your intake manifold. If you touch the "wet" spots, does it seem like oil? And after you touch the stuff, what do your fingers smell like?
2kMaxim may be right about a coolant leak. When the engine is cold, remove the radiator cap. The radiator should be full all the way to the top, no air space.
Old Mar 27, 2013 | 10:10 PM
ookami85's Avatar
I'll have to try touching it tomorrow and check the radiator cap. But the coolant reservoir isn't empty though.
Old Mar 28, 2013 | 12:41 PM
ookami85's Avatar
Ended up bringing it to the shop. Blown valve cover gasket causing oil to leak out and something about the pcv and something getting into the exhaust causing the smell. Not sure how all that works together. 300 to 400 to fix.. Car is starting to cost me more than what it's worth. =[
Old Mar 31, 2013 | 09:12 AM
steezmuffin686's Avatar
but dont you feel better about the fact it wont smell like "glue" anymore? lol, i prefer peace of mind over cost value of car. imho
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Samedi
Aug 13, 2015 04:05 PM
Balkins
Aug 12, 2015 06:39 AM
