did a RSB or FSB help u?
Old Jan 12, 2002 | 06:54 PM
Dasyce's Avatar
I know this has probably been asked before.. but since i'm impulsive and am considering purchasing a RSB and FSB, I was wondering if either of these mods will help to reduce steering wheel vibration at highway speeds?
Thanks in Advance!!!
Old Jan 12, 2002 | 07:02 PM
sbslacker's Avatar
Re: did a RSB or FSB help u?
No. Steering wheel vibration at highway speeds is a result of improperly balanced tires. The FSTB and RSB should have been standard equipment on the Max (as they are on the Infiniti's) considering how much they improve the handling of the car. Get them.
Old Jan 12, 2002 | 07:08 PM
KWheelzSB's Avatar
Re: Re: did a RSB or FSB help u?
Ditto - time for a 4-wheel balance.
(Definitely get the mods., tho! RSB is most significant)
Old Jan 12, 2002 | 07:23 PM
costcowholesale's Avatar
??????i30 comes with rsb?
Old Jan 12, 2002 | 08:16 PM
sbslacker's Avatar
Re: Re: Re: did a RSB or FSB help u?
I know FSTB's are on some of the Infinitis as standard equipment. But now that you mention it, I'm not sure about RSB's....
Old Jan 12, 2002 | 08:52 PM
Vyrus's Avatar
Yes.
Of all the handling mods I have (the ones that I can speak of), the FSTB was the most help. I have FSTB, RSB, Sprints, 17"s wheels, and Yokohama tires. FSTB really makes the chassis lean significantly less.
-Cyrus
Old Jan 12, 2002 | 08:55 PM
Maxilicious's Avatar
Could also be bent rim
I took my car in for a balance on Friday because of a vibration at highway speeds. Ended up having a slightly bent rim. Anybody want to buy it?
Old Jan 12, 2002 | 09:43 PM
RedMax95's Avatar
Re: Could also be bent rim
ya the mods are def. worth it
Old Jan 12, 2002 | 09:51 PM
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
if its an impulse buy it will be one with great rewards!
my FSTB helped. my front end (structurally speaking) is more rigid. its noticeable in the steering wheel. i noticed a reduction in vibration (not like the steering wheel turning left-and-right/shaking like an imbalanced wheel/tire would cause, but a very, very subtle tuning-fork-like buzz) and much less kickback to the steering wheel when i encounter road irregularities. steering is smoother and it takes a bit more effort to turn at speed (which i like). i have better feel of the road (almost like an integra i had).
a rsb shouldnt effect steering wheel vibration (the obvious being that its bolted to the rear suspension), but RSB in general terms typically will help in leveling the ride in undulations (straight line or a curve). performance/handling-wise a RSB will kick ****!
get both dammit!!!!
Old Jan 12, 2002 | 10:05 PM
95emeraldgxe's Avatar
yeah - i like what the sway bars have done on my friends maxima.....can u name the brands that give the best bang for the buck, and at the same time the brand that gives the absolute best quality regardless of price (for both the rear and front).
Old Jan 12, 2002 | 10:11 PM
KWheelzSB's Avatar
Addco - best bang for the buck
Stillen - best
Not aware of anyone going for a bigger FSB, so maybe someone else can chime in on that if they know anything. . .
Old Jan 13, 2002 | 01:48 PM
DARTHSWAN's Avatar
Juss Do It
thatcollegestudent
18
Oct 5, 2015 02:29 PM
magnetik
Aug 22, 2000 01:39 PM
