Whining from speakers after HU install
I am getting a whining coming from the speakers after installing an aftermarket head unit. I have redone all of the grounds and after checking wire by wire, I have found the culprit. it only whines when I power up the factory BOSE amp. I didn't have an issue with the factory head unit, but I am with the aftermarket. I am confused as to why I am having this problem. Any ideas?
Just to say it over again then to make sure im right...If you have BOSE SPEAKERS & AMPS I think you're using the wrong wiring harness....I'll try to edit the post with the right harness if i'm correct
Mar 12, 2020 12:06 AM
popdedop
Sep 11, 2015 11:17 AM
