1998 A/C switch
Old Mar 30, 2013 | 12:55 PM
joeveebee's Avatar
1998 A/C switch
Hello,
I have a 98 Maxima and the little push button A/C button no longer turns on the A/C. The A/C does come on when you hit the defroster buton and blows cold, but out of the defroster vents. I have two questions.
1, Can I replace this push button with some kind of generic toggle switch in the dash?
2, If so, whats the best way to get into that area and remove the heat/AC control unit?
Thanks for any help
jVB
Old Mar 30, 2013 | 03:19 PM
DennisMik's Avatar
I will assume that you do not have the auto climate control system. In the manual controls, all those buttons go into a printed circuit board. If you repair printed circuit boards, you know what kind of a task that is.
I think it would be easier to get the control panel from a junkyard and install it. I paid $20 for mine and it was not a pick & pull junkyard. Pick & pull are usually less.
To take the control unit out, you take the radio out and the control unit is mounted in the frame with the radio. Do a search for radio removal or remove the radio or something like that.
Old Apr 1, 2013 | 06:56 AM
joeveebee's Avatar
Great, thanks,, I will look into that.
Thanks for the respose.
jVB
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
leatherneck
Sep 30, 2015 09:16 PM
uttadms31
Sep 30, 2015 05:24 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
