HELP! Coil pack grommet stuck in spark plug cylinder.
Old Mar 31, 2013 | 06:09 PM
Zach-R's Avatar
Well had a productive weekend installing headers and some other things now its time to put it back together and i cannot get the coil pack grommet out! Ive tried everything i can think of, long screw drivers, air nozzle, clothes hanger bent into a hook. Now the grommet is all tore up...
Any ideas other than pulling the head off? FML!
P.S. In the market for a used oem coil pack.
Old Mar 31, 2013 | 06:12 PM
Vacuum?
Old Mar 31, 2013 | 06:25 PM
Zach-R's Avatar
It's really stuck in there I don't know if it'll work or not and my vacuum sucks(no pun intended). I may try to get a spark plug socket on the plug and get it out. If some rubber pieces fall into the cylinder how badly could that turn out lol?
Old Mar 31, 2013 | 06:58 PM
BlackThornDemon's Avatar
pics?
Old Mar 31, 2013 | 07:14 PM
Zach-R's Avatar
Originally Posted by BlackThornDemon
pics?
I can try to get some here in a bit. Im getting a pair of really long needle nose tomorrow to try. I hope they fit down into there.
Old Mar 31, 2013 | 08:59 PM
Zach-R's Avatar
Got lucky and got it out by stabbing it with a screw driver and carefully guiding it out. Crisis averted! Thanks all.
Old Apr 1, 2013 | 05:10 AM
njmaxseltd's Avatar
This is in the stickys. Put crazy glue on the stalk, put it back together. Drink 1 beer, pull coil out with everything glued together.
Old Apr 2, 2013 | 08:14 AM
98sleeper's Avatar
I had to pull mine out two days ago with a hook pick with a sharp end. It stabbed through and pulled right out. This happened to three of my coils.
Old Apr 3, 2013 | 03:51 AM
Zach-R's Avatar
I actually damaged my grommet and couldn't reuse it. Should've checked the stickies I'm sorry.
Old Nov 17, 2015 | 06:30 PM
ik95's Avatar
My rubber boots are stuck as well in three cylinders. Once I pull them glueing helps??....also have misfire in third cylinder bc there was oil in there....I changed the valve cover since and cleaned out oil as much as I can...kept the old spark plug and coil pack...still get misfire now....should I check spark plug and coil...or just one or both?...trying to avoid buying new coil..
Old Nov 18, 2015 | 05:10 AM
jerrod99_se-l's Avatar
Replace the plug...check the coil...or swap it with another coil..
tarun900
19
Dec 20, 2021 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
