EGR blockoff
EGR blockoff
99 max SE, i want to blockoff the EGR tube. cleaned it a couple years ago & the P0400 code is back. dont want to go through that again so my question is what to do with the sensor? if anyone can help, i'd appreciate it. the code needs to be clear to pass inspection
I got a 240sx block off plate from eBay to see if they were the same. They are not however all I had to do was cut the ears of the plate a bit and it works. It was only $7. I also drilled and tapped the plate for my old egr sensor so it could go somewhere instead of just hanging.
Now I have not driven the car yet so I'm not sure if I will run into a cel or not by having the sensor in the intake. I can report back once I get her back on the road this week. I did remove the sensor from the tube for a week as a test to see if I would throw a code and I did not.
Also when I removed the entire egr assembly I had coolant and vacuum lines attached to a bracket on the egr system. I removed the lines and bracket, capping the vacuum off and looping the coolant lines that ran through the Intake manifold and throttle body. I'm sure I will have a high idle now but I can fix that.
I have one test fitting it but you can't see much Ill edit this post when I get home and post a picture. It was just a tad too small and the bolt holes didnt line up. I just cut straight out from the bolt holes so I could bolt it down.
Here's a link to the plate on eBay.
http://www.ebay.com/itm/260576683588?redirect=mobile
Simply because I didn't just want it hanging somewhere. Also just to appear a little more stock. If there's a sensor hanging with nowhere to go its a little obvious that something is missing. Just personal preference.
Nissan 240sx EGR Delete Block Off Plate KA24 KA24E | eBay
Thanks, schmelly, I was installing headers and I figured I might as well remove the egr since I have a 01 vi laying here.
Anyways I got the max running last night and no egr codes. However I had to remove the fast idle thermo valve because I looped the throttle body coolant lines. The 240 BOP does work just requires a little modification for those who don't want to make a BOP from scratch. Good luck.
What do you do with the tube from the exhaust to the intake? Anymore photos of the procedure? Any CEL? My car is currently throwing the EGR flow code.
I wish to do the block off to not have this issue!! I just want to make sure that I dont have an issue and no more CEL.
Thanks in advance.
PS: on my old car (Neon) if you blocked the EGR, you blocked both the intake and exhaust with plates, but without a performance computer or stand alone or using a diode you would get a CEL.
Thanks in advance.
Actually the block off plate bolts onto the intake manifold. I couldnt find a bolt to fit the egr bung on the rear header. So I had a friend weld it shut. You will not get a code if you leave the sensor plugged in. You can do something like I did or just let it hang. Id atleast zip tie it somewhere. I have a few pictures but i dont know how helpful they will be.
Here's the pile of junk I removed from the engine.
Header welded up.
Here's the coolant lines looped and the vacuum for the egr capped off. Reason for looping the coolant was it was a pain to deal with when removing the intake manifold and I didnt want to have to deal with it when installing my 00VI.
I hope this helps some and sorry about the pic quality.
Header welded up.
does anyone know what sets off the code, is it the sensor's resistance?
havent driven enough to know, but i tested the sensor & it works. EGR coils measure correct.
i can hard-wire a resistor in place of the sensor if that would work. maybe disconnect the EGR solenoid too.
Your best bet is to try to connect it in some way.
There are ways to get the code to go away, but not a resistor, and not removing it.
I would just ignore the light and check codes every now and then.
You could always do the bulb mod and just unplug your CEL bulb.
Kansas resident here...
The above posts say they just tuck the temp sensor on the heater hose sleeve.
Tricks the ECU.
