Another No Start Thread
OK, so I have a 95 max that refuses to start. I have narrowed it down to a fuel problem. I did full tune up, changed the fuel filter, fuel pump, cleaned the grounds, changed the starter, bought new cam and crank shaft sensors, cleaned the throttle body, and changed all the fuses under the dash. All to no avail. I know that my battery is good because it is also a few months old and while I am troubleshooting, I keep the battery on a trickle-charge charger. As a result, I don't have to worry about ever having enough juice. I confirmed that there is fire because after spraying start-it in the intake my max starts, which implies that I have fire. After it starts if left to idle it dies. If I attempt to rev it makes a crackling sound which seems to imply the injectors are starving for fuel. I also had a buddy of mine check the injectors and he said they seem fine. I even hear a hiss when the key is in the on position so the fuel pump is working and I have verified that fuel is shooting up when I remove the hose on top of the fuel filter. At this point I would like to know what regulates the fuel reaching the throttle body? Are there any sensors that could be the culprit here or does anyone have any suggestions because I am stumped.
On another note, I have a rare throttle body with a single connector (not the usual throttle body with two connectors that most other 4th gens comes with). I am not sure if this makes a difference, but someone plz help!!!!
Since you think you have a fuel problem, you need to prove or dis-prove that.
A fuel pump making noise is not a guarantee that it is pumping gas. You need to disconnect the fuel line and see if gas is coming out. You also need to determine if the fuel injectors are working. There is a red wire going to each injector that has 12 volts on it to power the injector. Turn the ignition key on and see if you have 12 volts. Then you need to determine if the fuel injectors are firing. Listening to the clicking sound they make is probably the easiest way. You need to use a stethoscope (or a substitute) for that.
The fuel pressure regulator could also be a problem, not allowing fuel through it.
the ecu not getting a signal from the tps can also make starting the car a pain can you post a pic of your throttle body
This is the only picture that I have now, but I don't know how helpful this will be...it is a link to my album:
http://forums.maxima.org/picture.php...ictureid=33967
Thanks also for your quick reply luke95gxe. OK, I will try to take pics this weekend when I go home, I'm at school now. I am not familiar with testing signals to the ecu...how would you suggest to go about testing this luke?
I believe the wires should be all original. A buddy and I changed the motor here in this pic but we hooked everything back up and the car was running like a dream for a couple months, actually much better than with the motor that the car came with, which showed signs of a blown head gasket. I will work on getting better pics this weekend.
Anyone know why this guy...or me for that fact wouldnt be getting any fuel?
So far I have...
replaced fuel pump
replaced the cam sensor
verified no fuel sisquirting out of the fuel line
tried to replace the relays
It cranks but no starting
THanks, Labrat
So far I have...
replaced fuel pump
THanks, Labrat
have you tested the pump????
Finally broke down and took it to my auto electrician. HE said he thought the car might have been sitting for awhile. The security fuse looked to be nasty from his description so he cleaned it up and WHALA it runs again!!!! Moral of the story is to check any and all fuses even if you think they are unrelated. This explains the no fuel and no spark!!!!
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
trungg86
Sep 4, 2015 04:58 AM
