Cylinder 6 Misfire... what to do?
Dad turned on the engine in his 98 Maxima SE on the way back from grocery store, and engine started shaking the whole car. I read the codes by turning the ECU screw, and it says 0603, which is cylinder 6 misfire. Went and got a new platinum spark plug from AutoZone and put it in... problem remained the same.
He tried disconnecting coil electric connectors one by one to make sure its cylinder 6, and it is in fact #6 that is not working.
What could it be, and how do we fix this?
It is likely a bad coil but the wiring could be bad as well. Test the connector first before you buy a new one. If the coil is bad then only put in a Nissan coil. Either new or pull a part will do. Several members have tons of used ones up for sale so go ahead and post a WTB in the classifieds if new is too expensive for you
as per the Factory service manual that you can download here https://docs.google.com/folder/d/0B4...yNjE5OGJi/edit
The easiest way to check if the coil is bad is to unplug it while the engine is running. You already know it is cylinder 6 so the hard part is over. If nothing happens then it is bad but if the misfire gets worse then it is good and your wiring is the issue. Then, just to be sure, switch the bad coil into another cylinder(such as 4 which is right next to it). The misfire code should then move to cylinder 4 and you can buy a new coil and know you are not wasting your money.
Thanks, this is exactly what my dad ended up doing and it is in fact the coil that is not working.
So you are saying we have to only use coils made my Nissan? My dad went to a used parts place and the guy said a used one will be 30$.
Does anyone know how much a new Nissan one costs? Amazon, AutoZone, and Pepboys don't seem to have a Nissan one online.
^ this also is a good idea. I use to have a few i picked up a yard. Gave them to the guy that bought my old max. Definately have plans the hit up some yards and stockpile some items in the next couple weeks and more over time now that i have another max
Why do I have to get a replacement Nissan coil? Can I use a coil by another manufacturer, which will be less expensive?
My dad got a temporary coil, but I think it's from another car, not a Maxima. It works though.
After that go to your local JY and pick a few coils or put a WTB posting in the 4th GEN classifieds.
Thing is if you can get good used nissan coils at a yard, then why not? It will be cheaper than the aftermarkets and 9 out of 10 will still out last it. You can probably get atleast 3 maybe 4 nissan coils at a yard for the same price as a "am". If you have a pick and pull then probably all 6
jmlee44
Oct 2, 2022 02:13 PM
knight_yyz
Nov 1, 2015 01:34 PM
