wat size spacers with 01 17 inch rims on z32 bbk
Old Apr 18, 2013 | 05:32 AM
maxfever1987's Avatar
im doing a z32 bbk on my 4th gen, and im using the 2001 17 inch rims, i plan on geting ichiba hubcentrci spacers with extended lugs, i dont remember the offset of the rims but def. need spacers in the front, my question is does anyo0ne know the minimum size spacer i would need?im not trying to push my wheel out all the way but i need to clear the calipers, so i need to know the minimum size spacer i would need to go with this?thanks
Old Apr 18, 2013 | 06:56 AM
NmexMAX's Avatar
dot dot dot ...
Minimum would be 25mm.
Did some test fitting at one point and yeah, those wheels (mine were 03 17's) have an unfriendly offset AND and bad spoke design for a BBK.
Test it out. Test fit the calipers and then try and put the wheel on and use washers, in this case, washers would be plentiful so try and take some rough measurements.
http://www.blehmco.com/300ZX_brakes.htm
What wheels will these fit under?
I have tried this kit with several wheels so you can get an indication of what will fit....
These kits DO NOT FIT UNDER THE STOCK 17" Maxima wheels!
So far, every aftermarket 17" and 18" wheel I have tried will fit, but the 17s get close on spoke clearance--depending on wheel design. I am currently trying to compile a database of all of the wheels that fit these kits to give you an idea, but the best way is to simply measure for yourself. I make no claims to wheel fittment, but for a general guess on if they will fit or not, use these measurements:
Measure 5 1/4" out from the center of the wheel to one of your spokes. Now measure the distance from the surface of your stock rotors. If you have at least 2 1/2" of clearance here, then you should be fine with the kit. I can tell you for certain that 300ZX (Z32) wheels will NOT fit without a 1/2" spacer.
Old Apr 18, 2013 | 06:44 PM
Cebby's Avatar
I know these aren't 5th Gen wheels, but for the record, 6th Gen 17" 2004-2006 SL wheels are BBK friendly (nice high clearance spoke design)
They fit over this kit with no spacers. Fastbrakes BBK
Old Apr 19, 2013 | 03:18 PM
seriously 25mm?? wow, my friend with the 02-03 se has wilwoods in the front 4 pistons and he is using 10mm, i though 10-15mm would do it for me
Old Apr 19, 2013 | 04:30 PM
RA030726's Avatar
I'm nutty for Nissans
By the time you buy 4 spacers, I think you are better off getting different wheels.
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Garrettz459
Sep 28, 2015 02:50 PM
