how do you take out the cornering lamps?
Old Jan 13, 2002 | 08:24 PM
bluman3's Avatar
i am trying to changed the bulbs in the cornering lights. please help.
Old Jan 13, 2002 | 08:33 PM
95GreenGLE's Avatar
if you mean the clearance lights next to the headlights.
-pop your hood
-remove the philips head screw on the top near the corner of the headlight
-pull the light out. it comes out hard because there is a rivet-pop thing you have to pull off.
Old Jan 13, 2002 | 08:39 PM
bluman3's Avatar
thanks. i took the screw out but was scared that i was going to break it. i thought that there was something else besides that rivet.
Old Jan 13, 2002 | 08:43 PM
WaarrEagle's Avatar
It is a lot easier if you take a flat head screwdriver and stick it down to where that rivet thing is. Just put it where it separates and give it a quick turn and the light comes right off. It also feels much better for the light than just tugging until it pops.
Old Jan 13, 2002 | 08:46 PM
tabridge5's Avatar
make sure you wrap a towel around the flathead screw driver so you dont mess up the lights
Old Jan 13, 2002 | 08:47 PM
gtr_rider's Avatar
192.168.1.1
Thats the easiest way, mine just popped out with that trick.
Old Jan 14, 2002 | 06:36 AM
njmaxseltd's Avatar
Why do you guys take the lens out to change the bulbs? Just sneak your hand in there and give a twist. The socket pops down and out. Change the bulb and sneak it back up in there. I have pretty big hands, ahum... and I can get to it no problem.
Old Jan 14, 2002 | 10:22 AM
hockeyghst's Avatar
yeah over the summer my uncle tried popping it out with a screwdriver and busted the lense...i went to a junkyard to get a replacement and the guy did have any and i had to order a NEW set from another place...well my dad is friends with the guy so we got a discount...i go back the next day and the guy gives me this lil azz box and im liek wtf??? they ordered the turn signal pieces instead of the clearance parts....in the end i got 2 brand new clearence lights for 15 bux
Old Jan 21, 2002 | 05:36 PM
packetattack's Avatar
Why remove the lens? Do it from the bottom
I agree with njmaxseltd, I use the same technique as reaching under the light and just twisting. You can even use a flat head screwdriver to push the tabs to get it to move.
Old Jan 22, 2002 | 09:21 AM
vitas's Avatar
use some WD-40 and pop it out with a screwdriver. Its hard to put it back in though.
Old Jan 22, 2002 | 10:02 AM
Llfe's Avatar
that's the best way of doing it...using WD-40...i had to use it to get it out...i freakin asked the dealership how to get it out and they were like yea...there's a screw at the bottom...i'm like wtf...oh well...i got it out...it's not hard to put bak in though
Old Jan 22, 2002 | 11:27 AM
maxnewbie's Avatar
Can the bulb (white) that is currently in there be changed to another color bulb, i.e. bright yellow like the ones on the Lexus? If so, what would the wattage be?
Old Jan 22, 2002 | 12:06 PM
99MAXSE-L's Avatar
yeah i couldnt open those damn clearence lights!!! so i just popped my hand in the back and changed my lights using the method above...
Old Jan 22, 2002 | 12:31 PM
thebigsadler's Avatar
put a screwdriver back there with a towel and SNAP that gay click off!!!!!!! I was tired of messing with it EVERY time you want to change your light in there (my hands are way too big to fit in there without taking the lense off), then all that holds it on is that screw.. works great..
Old Jan 22, 2002 | 12:55 PM
njoph85's Avatar
piaa
is the clearance light next to the head light??
i am going to replace the head lights and the foglights with piaa superwhites. should i replace the clearance light with piaa's also so it all looks uniform or will it look ok with stock bulbs.
when you guys say light do u mean bulb or the whole part?
Old Feb 7, 2002 | 03:10 PM
blackmxma's Avatar
Yeah, I went by the dealership and the guys said the same thing..."theres a screw down there and you have to take out the headlight to get to it." but that don't make sense cuz you gotta take out the clearence lamps to get out the headlight housing, right?anyways, then they tried charging me 24 bucks per lamp to get them out for me, so I said f*** it and left. I'm still tryin to get mine out.
Old Feb 7, 2002 | 04:06 PM
Llfe's Avatar
stupid dealership...oh well...keep on trying...main thing is use wd-40...cause w/o i woulda never got it out...if u live in so-cal i'll take it out for u
Old Feb 7, 2002 | 07:21 PM
blackmxma's Avatar
I finally got it. I tried that twisting the flat head thing and it worked nice. Before I was tryin to just pry it and it felt like it would break. Anyway, I'm not in So-Cal, but next year I'm movin to Central Cal!
Old Feb 7, 2002 | 10:51 PM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
I also used the twisting trick to get my clearance lights out. Then I did what thebigsadler and pop out that stupid plastic thing holding the rivet. It is way easy to take off now if you ever need to again. That's cool you gonna move to central ca. Where at? I think me and Nismo are the only org members here that are from the central valley. Hit either of us up if you have any questions.
Old Feb 7, 2002 | 10:56 PM
SuDZ's Avatar
Is the socket in the same place as where the power plugs in? I was wondering if I could get it out without removing it. It would be much easier.
SuDZ
Old Feb 7, 2002 | 10:57 PM
SuDZ's Avatar
Oh another thing... where is the rivet? I did not see one.
SuDZ
03VQMAX
Oct 2, 2016 09:36 AM
03VQMAX
Nov 10, 2015 03:39 PM
NERDJUSTBNME
Sep 30, 2015 03:20 PM
Blkkn8
Sep 22, 2015 06:37 PM
conansriver
Sep 16, 2015 12:17 PM
